3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Robot Brain: Build a single board computer in an evening
Step 5Wire up the serial header
The header on the board is designed to go to an IDC 9 way ribbon cable, and then to a D9 male plug. The only trick is that the 10 way header is designed to take 10 way ribbon cable. If you use 9 way cable there is a gap for the missing wire. I've taken a closeup to help clarify this. If you wire it up right then pin 1 on the board goes to pin1 on the D9. Pin 5 on the D9 should connect to earth on the board. If those two are connected the rest of the wires will be ok too.
Wire 1 is on the left of both views of the ribbon cable. You could use ribbon cable with colours if you like.
The messy stuff on the IDC plug is hot melt glue. Probably not necessary but it makes things a bit stronger.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:James Moxham
Dr James Moxham is a general medical practitioner in Adelaide, Australia. His interests include general family medicine, medical politics, microcontrollers and tending a rose garden. He lives on a pro...
more »
