Step 6Download some software
Let's grab the hex file of xmodem from here: http://n8vem.googlegroups.com/web/xm50_LB1.zip?gda=O2tYn0EAAABRoI8ydU505jGCwGWcAnRL1RQ8Aj5bHZQJ6hxcf7VyVbwBih-m421sIN3Oibiyd_vhtrFcBixfottYTQUy-Muj7WbB0sVAO2Hmgtm1PE2xNg
Unzip it and you will get two files. You need the one that ends in .hex.
Now we need to send this to the board. You need a terminal program, which emulates a monitor and a keyboard for this single board computer. Windows has one called hyperterminal which usually hides in the start/programs/accessories folder. Or you can use hyperterminal private. Or Teraterm. Or absolutetelnet. Or a dos based program called conex. There are lots of terminal programs around because this was how you dialed into the internet before broadband.
Lets fire up hyperterminal. It will give you three screens and you need all the settings correct! Once you have entered this once, you can save this session and it will create a little file ending in .ht If you then click on that file (drag it to the desktop so you can find it later), it will start hyperterminal with all the correct settings.
First screen=name the connection. Call it SBC and choose an icon.
Second screen. Set the com port. My computer defaults to COM2 on the setup screen, and it needs to be changed to COM1. Go ahead and change to COM1.
Third screen. Baud rates etc. Set the bits per second to 9600. 8 Data bits. Parity to None. Stop bits to 1. And Flow control to None. You will probably only need to change bits per second and Flow Control.
Now you will be presented with the terminal screen. Connect up the board to the serial port and power it up and you should get a welcome message.
If not then get on the Google group and ask for some help.
Now it is time to talk to the board!
Add Comment
