DARwIn-OP is an acronym for (Dynamic Anthropomorphic Robot with Intelligence - Open Platform) or DARwIn for short. The DARwIn-OP was developed by the RoMeLa research lab at Virginia Tech in collaboration with University of Pennsylvania, Purdue University and ROBOTIS. ROBOTIS is a world leading South Korean robotics’ company. Their Dynamixel servos are the leading robotic servos in the world and the key to why the DARwIn-OP is so ground breaking. The lead designer of the DARwIn-OP project has Dr. Dennis Hong of Virginia Tech’s RoMeLa and ROBOTIS. The robot is a state of the art research and development humanoid robot. The DARwIn-OP weighs in at about 2.9 kilograms and a height of 45.5 cm.
The idea behind this project is to find new and cheaper ways to create and build robots. As 3d printing becomes cheaper and easier to use more and more people will have access to this way of manufacturing. I hope that this instrucable will open up more peoples eyes as to the power of this new personal fabrication method.
Below is a link to my Make magazine article on how I made the clone.
http://blog.makezine.com/2013/04/26/cloning-the-darwin-op/
Step 1: Why I wanted to own a DARwIn-OP!
This is video of the DARwIn-OP in its natural environment Robocup soccer.
Step 2: Download CAD file
Link to file location.
Other download information links
Step 3: Create .STL files for all of the parts.
If you need a cheaper way try AutoDesk 123D Beta if you can still download it.
Here is a link to my Thingiverse project page for my DARwIn-OP clone where I have upload all of the .STL files for the robot.
http://www.thingiverse.com/thing:9793
DARwIn-OP STL.zip19 MBStep 4: Print out all parts on a 3d printer.
UP! Plus 3d printer.
The Afinia H-Series: 3D Printer is the exact same printer.
Step 6: Buy your servos for the robot.
Link to where to buy them.
Step 7: Buy fastners for the robot.
http://www.mcmaster.com/
Step 8: Assembly Robot
Step 12: Redesign parts that break
Step 17: Robot is working!
Total cost for my project was 6000 USD if you don't include the 3d printers that I used. A lot of money yes but if you buy a factory made DARwIn-OP from Robotis the cost is 12,000.00 USD. So I saved about 50% of the cost of the robot by building it myself.
If you are interested in following future upgrades and mods to this robot you can check out my blog.
http://mike-ibioloid.blogspot.com/
Step 18: Future upgrade possibilities.
Simplest would be changing there color to hardest which would be modifying their design.
A great example is changing the color of the covers to mimic the Ironman power suit.
Jet-pack and weapons for the power suit may take some more time and research.
The images where created in AutoDesk Inventor by my friend Yoshihiro Shibata.
Visit Our Store »
Go Pro Today »
Thanks,
Vic
Which parts of your robot failed first? Were those the metal replacement ones? Is your version lighter than Robotis version? Did that affect the kinetics?
I think people just assumed that you could not print out the brackets. I think I am opening a lot of eyes to the possibilities of what 3d printing can do.
The UP printer uses ABS that is very similar to ABSplus the Dimension printers use.
My version is lighter but you can can changes parameters in the DARwIn software as it is open source.
I have found that 3d printed parts are more flexible than metal and that strength is not that big of a issue.
I live Kansas City, Missouri, USA
I should be going to the Bay Area, Kansas City, Detroit and New York maker faires this year and Robogames.
You can also find early examples of the DARwIn-OP that used AX-18s too.
That is my next project idea. A cheaper DARwIn-OP that uses AX-18 servos, a raspberry pi and the CM-900 servo controller. Just need to find time in the day to do it!!:(
The downside to these bots though is they can't carry much in the way of sensors though. We need to shrink the Kinects sensor down to its size! :D
http://www.fit-pc.com/web/
http://www.robotis.com/xe/darwin_en
But that is a good idea though, you can use the raspberry pi and the CM-900.
check here for how to do it.
http://www.robotsource.org/xe/index.php?mid=Circle_CM9_Developer_World&page=2&document_srl=10624
http://spectrum.ieee.org/automaton/robotics/robotics-hardware/handson-with-the-next-generation-kinect-primesense-capri#disqus_thread
I need to redesign the head but it would fit!
Also, I don't think a Raspberry Pi would really cut it in terms of processing power to make a viable robot. Even the FitPc2 is sometimes lacking in speed with its two (hyperthreaded) cores. Probably the most demanding requirement of the robot is vision processing. The software that Robotis provides does a very basic job of colour segmentation, but it's not robust enough for soccer competitions. I'd really love to see a small GPGPU on the platform somehow.
http://robogames.net/events.php
Not sure if I will ever have the money for 4 DARwIns and the money to go to a Robocup event and compete in it.
Humanoid
Soccer Humanoid League
In the Humanoid League, autonomous robots with a human-like body plan and human-like senses play soccer against each other. Dynamic walking, running, and kicking the ball while maintaining balance, visual perception of the ball, other players, and the field, self-localization, and team play are among the many research issues investigated in the league.
The league is divided in 3 subleagues, according to robot sizes: Teen Size, Kid Size and Adult Size."
My question to you is what servos would you use?
The DARwIn-OP was design as a research and development robot.
A great example of what it is used for is Robocup. I don't think you would get very far in Robocup using standard servos. What do you think?
Go for Dynamixel then!
Still I think, for regular hobby use and low-cost research, I think servo is sufficient assuming you are able to tweak a servo for feedback.
One method is to use a magnetic sensor. A guy had made a nice magnetic sensor and that was very cheap. It gave great results and he was selling it a few years back. I would post the link of that if I find it.
Another obvious method is make hole in the servo and read the pot directly. Here's a tutorial for it. http://letsmakerobots.com/node/27206
Of course in any of these methods you would have to open and modify the servo that might void your warranty. But looking at the price difference between a Dynamixel and Servo, warranty is not a big issue.
When most people talk about regular servos they mean 10.00 analog servos from China. I have used them on lots of projects but they just do not have the holding torque, speed or resolution for humanoid robots.
http://www.robotis.com/xe/dynamixel_en
Even the low end AX-12s from ROBOTIS blow them away.
The only servo line that compares too them is the Kondo line of high end servos.
http://www.kondo-robot.com/EN/wp/?cat=14
I would tell you good luck and keep me updated on your progress.
yes very sweet servos!!
