Step 5Optional - add some data logic to reduce PWM needs
I was used to thinking of robot wheels in terms of two control pins, enable and direction. The enable pin was where you put your PWM signal and direction was a simple binary for forward/reverse. So you would need only two PWM signals for the robot, one for the left and one for the right. Here's my quick and dirty digital logic for it. I was going to use simple TTL circuits and a couple of 74HC Chips,
74HC04 - hex inverter
74HC08- quad 2-input AND gate
Now of course in my parts bin I don't have any AND gates, I only have NAND gates. So I was going to use the leftover inverters from the hex to do the job, and the two chips would have everything I need. That would work, but after playing around with it I decided to not go to the trouble - again YMMV. I will say that on a solderless breadboard this is a lot of wires .
Add Comment
