3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Robot Racer
Step 3Drilling the holes
Drilling the holes
Now we are going to drill the holes for the wheel rod (axle) to go through.
If you have a thin tube you can use the rod itself to poke the holes. My tube was quite thick so i had to drill the holes.
If you are going to drill you will need to find a drill bit that is slightly larger (1mm larger is good) than the stick you are going to use.
Making the hole slightly larger means there will be less friction on the rod and the car will go further. !
Use a ruler to make sure the holes are in line.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
356
Author:=SMART=
I make lots of different instructables, I make stuff i need or want, then show you ! ............................................See my profile for further awesomeness :) ..............................
more »
