Step 9Rubber band mechanism
Basically one end of the rubber band is attached to a fixed rod and the other end is on the rear axle,
when the car is pulled back the elastic band is wound up and then when you let go it zooms off.
Steps for the front, fixed rod;
1 Cut another small section from your skewer, (same size as the height of your tube)
2 Drill a small hole in the front of your car, on the top.
3 Insert the rod into the hole
4 Loop one end of the elastic band around the rod
5 Apply glue to the end of the rod to secure it in place
Steps for the back axle;
1 Use a paper clip with a hook on the end to grab the elastic band
2 Loop the elastic band around the axle
3 Your done !
5
comments
Add Comment
Add Comment
