Robot Speaker
Published
Introduction: Robot Speaker
In this instructable, I will be showing you the necessary steps, and materials needed to make a Robot Speaker.
Step 1: Supplies and Tools
The supplies needed to make this Robot Speaker include: 2 Logitech S150 USB Speakers with Digital Sound, Adafruit Pro Trinket 5V 16 MHZ (1 piece), Neopixel 16 LED Ring with Integrated driver, some cable (about 10 ft), Sandpaper, 2 pieces of 12 in. by 24 in. Plywood, and glue.
Some tools that you will need to construct this Robot Speaker include: a soldering iron, a laser cutter, a polisher, and a wire cutter.
Step 2: Designing the Robot Moustache
We used onshape, a CAD program, to design our Robots moustache. First, we looked at a picture of a cartoon moustache on the internet. Then on onshape, we made some curved lines in the shape of a moustache. And finally, we laser cut that moustache out of birche wood.
Step 3: Making the Box for the Speaker
The next step is to cut out two pieces of 24 by 12 inch plywood, to create two 7 by 7 in pieces. Then, you have to cut out the other four pieces by calculating what would make a perfect 7 by 7 by 7 in cube. This is because you have to account for the fact that you cannot make a perfect 7 by 7 by 7 inch cube with 6 7 by 7 inch pieces.
Step 4: Breaking Apart Speakers
For this step, you want to take both of the Logitech S150 USB Speakers with Digital Sound, and break them apart on the sides so that you are able to take each speaker itself, outside of the shell.
Step 5: Connecting Speakers to Amp
The next thing you want to do, is connect the speaker wires to an aux cord or amp, so that the music from your phone can be played through the speakers.
Step 6: Putting Box Together
Now you should be able to put the pieces of wood together to form a cube. Put two pieces of wood that are the same size on opposite sides. Then you want to place all of the other pieces on the other sides that are missing. Finally, you want to hot glue or nail all of the pieces together. However, you should not nail/glue one of the pieces, as you still have to put the speakers inside.
Step 7: Making Holes in Cube
Now, you want to make holes in the cubes so that both of the speakers can fit, and so that wires can come out from the back. Then, you want to place the speakers inside of the holes.
Step 8: Put Everything Together
Now, you want to nail/glue the final piece of the cube on top.
Step 9: FINALLY
PLAY MUSIC!
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    Very nice speakers with such style!
