Robotic Newton's Cradle
513
14
Published
Introduction: Robotic Newton's Cradle
About: I am an American teaching English at Shangluo University, Shaanxi. I like making machines that do interesting but fairly useless things - I call them Quixotic Machines.
Here is my second attempt to automate the Newton's Cradle. This one doesn't require any modifications to the cradle itself. It uses 3 servos, an Arduino Uno , scrap wood, and some chop sticks plus a kitchen utensil hanger slider rod. Watch the video, ifun.t's
Step 1: Slider Servo
This picture shows the while rail at the bottom that I got from a kitchen utensil hanger thingy. I mounted an aluminum bracket on two of the sliders, connected that to a standard size servo via another aluminum bracket and a chopstick linkage bar. This pushes the claw mechanism to and from the Newton's Cradle.
Step 2: Forward and Backward Tilting Servo
On the slider bar you see a vertically mounted servo to which the claw is attached. This servo tilts the claw forward towards the cradle and backwards from it.
Step 3: The Claw
The claw or gripper is just a servo mounted on a piece of wood and connected to two chopsticks via wire linkage. It doesn't close exactly equally with both grippers but gets close enough to get the job done.
Step 4: Arduino Sketch
Finally here is the arduino program that controls the servos: (has a little garbage in it - need to clean it up)
#include
Servo servo1,servo2,servo3;
//int potPin = 2;
// select the input pin for the potentiometer
int servangle = 0; // servo angle variable int potPin = 4;
int potPin2 = 0;
int ledPin = 13;
// select the pin for the LED int val = 0;
// variable to store the value coming from the sensor
int valPot2 = 0;
int valInc = 4;
int currAngle = 0;
int newAngle = 0;
int delayTime = 0; //Analog read pins const
int buttonPin = 2;
void myServo(int curAngle,int newAngle,int angleInc,int incDelay,int servoNum)
{ if (curAngle < newAngle) { for(int angle=curAngle;angle < newAngle;angle += angleInc) {
if (servoNum == 1) servo1.write(angle);
if (servoNum == 2) servo2.write(angle); delay(incDelay); } }
else if (curAngle > newAngle) { for(int angle=curAngle;angle > newAngle;angle -= angleInc) {
if (servoNum == 2) servo2.write(angle); delay(incDelay); } } }
void setup() {
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
// declare the ledPin as an OUTPUT
//pinMode(buttonPin,INPUT);
servo1.attach(9);
delay(10);
servo1.write(145);
servo2.attach(11);
delay(10);
servo2.write(90);
servo3.attach(13);
delay(10);
servo3.write(90);
delay(2000); }
void loop() {
//Serial.print(" buttonpin= ");
Serial.println(digitalRead(buttonPin));
val=1000;
Serial.print(" delay val= ");
Serial.print(val);
Serial.print(" angle val= ");
Serial.println(valPot2);
digitalWrite(ledPin,HIGH);
//servo1.write(30); //150 to 30
myServo(145,30,1,10,1);
servo2.write(145); //90 to 150
delay(1000);
servo3.write(109); //80 to 110 - clamp
delay(1000);
//servo3.write(100); //80 to 110
//servo1.write(145); //150 to 30
servo2.write(130); //90 to 150
int y = 131; for (int x=30;x<146;x=x+2) {
//myServo(30,145,1,10,1);
servo1.write(x); //90 to 150
delay(30);
y = y-1;
if(y > 89) { servo2.write(y);
delay(30); }
//myServo(130,90,1,10,2); }
delay(7000);
servo3.write(80); //90 to 150 - open clamp
// myServo1(172,90,1,15);
delay(val);
//servo1.write(172);
//myServo1(valPot2,175,1,1);
digitalWrite(ledPin,LOW);
//cli();
delay(5000); }
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Thank you. One of my favorite projects. Tom Baker was my Doctor.
