Introduction: Robotic Piano Player
Made a simple robotic one finger piano plinker using two servos, Arduino Uno, some aluminum flashing and a fishing pole for the sliding rails. You get a gold star if you can identify the ditties it plays. You probably have to be an old person like me to know a couple of them.
Step 1: Fishing Pole Rails to Slide Finger On
Used a fishing pole and cut a couple of short sections to slide outside two longer pieces. Then epoxied them too some wood connectors. Connected the two outside sliding pieces with a wooden platform on which is mounted the aluminum holder of the finger servo.
Step 2: Built "finger" From Chopsticks
Made a single joint finger from chopsticks and mounted that to a servo.
So one servo for the finger and one standard size servo for the slider.
Step 3: Connect Servos to Arduino
Connect two servos directly to Arduino Uno 5vcc,gnd and signal pins 9 and 11.
Run Arduino sketch as follows:
#include servo.h
Servo servo1,servo3;
int ledPin = 13; // select the pin for the LED
void setup() {
Serial.begin(9600);
pinMode(ledPin, OUTPUT); // declare the ledPin as an OUTPUT
servo1.attach(9);
delay(10);
servo1.write(110); // put finger at starting position
servo3.attach(11);
delay(10);
servo3.write(71); // position slider at starting position
delay(5000); // wait 5 seconds before beginning
void playKey(int slidePos) {
servo3.write(slidePos); // move slider servo to key position
delay(300); // give slider time to get there
servo1.write(85); // move finger down and press key
delay(100); //give time to move finger down
servo1.write(110); //pick finger back up
delay(300); //give time to pick finger up before next slider move
void loop() {
digitalWrite(ledPin,HIGH);
/* playKey(165);//f delay(500); playKey(149);//g playKey(138);//a playKey(127);//b playKey(116);//c playKey(105);//d playKey(94);//e playKey(83);//f playKey(72);//g playKey(61);//a playKey(50);//b playKey(28);//c playKey(15);//d */
// cetk //
playKey(71); playKey(60); playKey(83); playKey(170); delay(400); playKey(116); delay(2000);
// avengers //
playKey(72); playKey(94); playKey(83); playKey(50); playKey(15); playKey(28); playKey(72); playKey(94); playKey(83); delay(2000); //amazing grace playKey(160); playKey(116); playKey(94); playKey(94); playKey(105); playKey(116); playKey(138); playKey(149); delay(2000);
//indiana jones
playKey(138); playKey(127); playKey(116); playKey(83); delay(500); playKey(149); playKey(138); playKey(127); delay(500); playKey(116);//c playKey(105);//d playKey(94);//e playKey(50);//c playKey(105);//d playKey(94);//e playKey(83);//f playKey(72);//g playKey(61);//a delay(2000);
//gilligan
playKey(138);//f playKey(105);//g playKey(61);//a playKey(61);//f playKey(61);//g playKey(72);//a playKey(94);//f playKey(116);//g delay(500); playKey(138);//f playKey(105);//g playKey(61);//a playKey(61);//f playKey(61);//g playKey(72);//a delay(500); playKey(138);//f playKey(105);//g playKey(61);//a playKey(61);//f playKey(61);//g playKey(72);//a playKey(28);//a delay(500); playKey(72);//a playKey(83);//a delay(500); playKey(94);//a playKey(116);//a playKey(105);//a delay(2000);
// somewhere over the rainbow
playKey(127); delay(300); playKey(50); delay(300); playKey(61);//f delay(300); playKey(83); playKey(72);//g playKey(61);//a playKey(50);//b delay(200); playKey(125);delay(300); playKey(72);delay(300); playKey(83); cli(); /*playKey(149);//g playKey(138);//a playKey(127);//b playKey(116);//c playKey(105);//d playKey(94);//e playKey(83);//f playKey(72);//g playKey(61);//a playKey(50);//b playKey(28);//c playKey(15);//d */
Automation Contest
Move It
