Robotic Solar Powered Sunflower
Introduction: Robotic Solar Powered Sunflower
Our sunflower is a tiny robot flower which has no mobility. It can only and continuously turns its face towards the sun like the sunflowers do.
Step 1: Parts
The robot sunflower is made from plastic parts taken from old CD drivers and junk home equipment; a small dc motor and reduction gear from the CD-R sawed together with some plastic parts, a tiny solar panel, some other plastic parts taken from an old aquarium filter and a simple, 4 transistor circuit made by me.
Our flowers uses the energy that comes from the sun to find more sunlight. So it continuously turns its face (the solar panel) towards the sun. As the same way sunflowers do. You can put it at balcony or window ledge. I've glued a magnetiesed CD holder disk taken from the old CD-ROM driver to the base of the robot. So when it is put on to a mettallic surface, it holds the surface firmly by the use of magnetic force.
Step 2: Where Can You Use?
anywhere it sees light. it will turn towards the sun with no need of external power.
if you use it inside your car, then every turn will affect its direction though it will simply follow the sun turning around the car.
The best way of making the mechanical assembly is as follows. The motor is mounted upside-down, the axle is connected to a magnet which will be used as the base of the flower, enabling it to firmly stick to any magnetic metal surface. Though the circuitry and the power supply (the solar panel) will be mounted on top of the motor, there will be no cables which are connected to the outside world, disabling the 360° turn of the flower.
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    Can someone give me a list of the materials, I am doing this project for science fair
    This circuit is a very bad design. The transistors produce a short-circuit across the power rail.
    Your site is still down. Google said your site contains harmful and/or malware software.
    checked it out and didnt see any problems.
    Is there away this can track the sun and charge a battery or power a device.
    Hi, This is brilliant! Thanks...
    Am looking to build one myself but am having trouble with the motor from the cd drive, any chance would you have more details for me to work with? Or would there be a similar low voltage motor I could buy that could work on the cheap?
    any low current, miniature DC motor should work.
    I would like to use it in a project, with a bigger motor to drive a bigger solar panel.
    Witch power transitors can i use ?
    Gtrz Aenhya
