3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Robotic Talking Turret
Step 2Electronics Pt 2: Sound
Sound is a very important factor of an animatronics project - however, it is usually very difficult to implement with microcontrollers.
So far I have only found one easy to use and cheap sound player for the Arduinos - the wave shield from Adafruit industries. It only costs about $25, much cheaper than other sound playing development boards. Also the coding is fairly simple with the libraries provided by Adafruit.
The disadavanges do pile up, though. It can only play uncompressed WAV files - in mono. It needs 8 connections do the Arduino. It takes a minimum of 10kb of flash on the Arduino - leaving only about 4 or 5kb left on the Arduino for the rest of your code. However other MP3 player boards usually run for around $100, so I just stuck with the wave shield.
I changed the dac.h file in the wave shield library to use analog pins 2-5 instead of the digital pins. I wired up a speaker to the base of the turret.
1 comment
Mar 27, 2010. 3:24 PMcucumber288 says:
do you need sound i just want to make one that fires
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:RazorConcepts
Check out razorconcepts.net for some projects.
