Piezoelectricity is the charge that accumulates in solid materials in response to applied mechanical stress. Substances that exhibit piezoelectric properties to a greater or lesser extent are crystals (Tourmaline, Quartz, Topaz, Rochelle salt and sugar cane), certain ceramics and biological matter such as bone, DNA and various proteins. Quartz and Rochelle salt exhibit the greatest amount of piezoelectrical properties and since the ingredients and instructions for making Rochelle salt are relatively straightforward I decided to make some to play with. I found some helpful guides
here and
here, but diverged from both guides several times without ill effect. Here are my instructions for making Rochelle salt (Potassium Sodium Tartrate), which yielded at least 5 tablespoons full of the salt and several large single crystals in a few days.
I've recorded two mechanical force tests of a single crystal using both a digital and analog oscilloscope
here.
The recipe calls for cream of tartar (Potassium Bitartrate or Potassium Hydrogen Tartrate) and washing soda (soda ash or Sodium Carbonate). Cream of tartar is a byproduct of winemaking; as the grapes age this acidic salt forms on the barrels of wine and is collected and used in a variety of household purposes, from preventing sugars from crystallizing to an ingredient in baking powder to stabilizing egg whites in recipes. Washing soda is highly alkaline (pH of 11) and often used as a water softener. It can be extracted from the ashes of plants and is sometimes used to make German pretzels. Washing soda can be made by heating baking soda (Sodium Bicarbonate or Sodium Hydrogen Carbonate) in an oven to break and evaporate the bonds of hydrogen to leave the Sodium Carbonate.
Your recipe is very reliable, I do however have a ? Washing soda [na2co3.10h20] is a very accessible chem. Your calcination? method is logical but energy dependant? Na2Co3 has an R.A.M of 106.0 the decahydrate is 286.0 =[2.7]
if you use same proportions but use same scoop for both chems it work out well
Apologies if I am Saying what you are already aware of:-0
http://www.youtube.com/watch?v=nRFgY4_3lHU
And it worked pretty well :)
Hope your ideas are a success though and have fun.
And I'm not the only one! This study suggests efficiency can be as high as 95%!!! Wow!
http://adsabs.harvard.edu/abs/1984PhDT.........9E
I wonder what the volumetric capacity of piezos is like... Can't find anything in a quick google.
Make sure to buy the more expensive cream of tartar and look at the label and see if it says anything about wine. If it is from a wine distillery or wine making place, it should be the real thing.
But just to be clear, if you added too much washing soda ( as in you kept adding it even when the solution didn't bubble when it was added ), then that could have easily caused a problem too...
Good luck, I hope it works out,
Jedi453
Hope this helps, and thanks again,
Jedi453
I did some double checking on what I found on wolfram alpha. After finding I could get about 4 Tablespoons of Cream of Tartar from a 42 gram bottle, I realized that Wolfram Alpha must be assuming it's in a pure single crystal, or completely compressed. So it is very possible that the Cream of Tartar you would buy at a grocery store would be about 100 grams for 10 Tablespoons. I'm sure there's a similar set of circumstances with the Baking soda. I'm sorry to have "corrected" your statements that were probably already correct. In retrospect however, my mistake shows that these quantities should probably be represented in either units of volume or units of mass, but not both. This is just because the density is not really fixed.
Just in case it helps:
- 10 Tablespoons is about 150 mL
- 25 Tablespoons is about 370 mL
- 1 Cup is about 267 ( ~ 270 ) mL
The way I've been doing these conversions is with Wolfram Alpha ( again wolframalpha.com ). To convert one unit of measure to another, just type "(amount) (unit of measure you're converting from) in ( unit of measure you're converting to )". Of course replacing things as necessary. This works with mass as well, assuming STP, for example I used something like "100 grams of cream of tartar in tablespoons" as a search earlier to check the units. Again keep in mind with mass to volume conversion (and vice-versa) a certain ( possibly unattainable/unrealistic, at least in the kitchen ) density is assumed, as I just found out.
Thanks again for your awesome Instructable and taking my advice,
Jedi453
Thanks for the suggestions and the link. Don't worry, I already have a metric ruler and have used the metric system many times before. I just don't have any really direct approach to measure mass in grams. I was just trying to double check that the measurements were correct.
The instructable originally had approximate measurements in tablespoons and grams. The numbers didn't seem to correlate to me, so I just wanted to double check them. I find that Wolfram Alpha is more than enough for me when converting units, it's just that if the units aren't of the same type, it makes assumptions on the relationships between the types. In this case, when I tried to convert grams to tablespoons, since the gram is a unit of mass and the tablespoon is a unit of volume, it made an assumption about the density of the chemical in question. This problem does not occur for converting between units measuring the same type of quantity.
Thanks again, Jedi453
