3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rock Band Stratocaster Stomp Box Overdrive Pedal
Here's how to add a pedal to your Strat to active overdrive with the stomp of your foot for under $20.
Step 1Parts List
Parts List
Things you'll need to have:
1 x Rock Band Fender Stratocaster Guitar Controller (with it's warranty prepared for departure)
1 x Phillips screw driver. I'm sure Phillip won't mind.
1 x Wire cutters/Wire stripper
1 x Solder Gun with some solder
1 x strand of double wire, as in speaker wire, or really any decent small gauge wire you can find
1 x Hot glue gun with some glue sticks. (Some might consider this to be optional)
1 x Drill with drill bit. Or a Dremel. Or a round file. Or something else that will make a 1/4" hole in the side of your beloved axe.
1 x Patience. Yeeeeeeaaaah. Just a little patience.
Things you'll need to buy if you don't have.
1 x Radio Shack Part# 274-0252 1/4" Mono Phono Jack. Panel mount, open circuit. UPC# 040293131401 (is a two pack in case you need to do two guitars or manage to lose/melt the first one) This will set you back about $3.
1 x Best Buy Lo Duca Universal Sustain Pedal Model# 3781 UPC# 013148037814. Of course you don't HAVE to buy this pedal but for $12 I think it's a good deal. Especially sense it has a polarity switch that allows you to step activate or lift activate. Meaning you can stomp this thing or lift your foot off of it to activate the switch.
5 comments
Nov 26, 2011. 12:33 AMFrozenIce says:
wait, what do u do next??? AAAAAAAAAAHHHHHHHHHHHHHHHH IMM SOOO CONFUSSEEDD!!!
May 7, 2009. 4:56 PMbobbyderf123 says:
thats really cool, but couldnt you technically just use a regular ps2 controller, put it in a box and and expose the select button?
Jan 1, 2009. 8:44 AMMisterHay says:
I've been thinking about a whammy pedal (like part of this or this), but I think you're right that adding an overdrive or star power stomp box to that would be fairly easy.
Dec 29, 2008. 9:56 AMmoesboy says:
this is awesome because the overdrive sensor on my controller broke im going to try this
Nov 1, 2008. 11:06 PMsimon4145 says:
In Rock Band 2 you can just use the kick pedal for overdrive. Plug it into the little jack at the bottom of the guitar.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:DEK1670
