Rock Band Whirligig
4,299
98
7
Posted
Introduction: Rock Band Whirligig
This is a project I shared with my friends on youtube for the Whirligig Wars Contest 2015.
A whirligig is an object that spins or whirls, or has at least one member that spins or whirls. Whirligigs are also known as pinwheels, buzzers,comic weathervanes, gee-haws, spinners, whirlygigs, whirlijig, whirlyjig, whirlybird, or plain whirly. Whirligigs are most commonly powered by the wind but can be hand, friction, or motor powered. They can be used as a kinetic garden ornament. They can be designed to transmit sound and vibration into the ground to repel burrowing rodents in yards, gardens, and backyards.
Source:Wikipedia
This is a quite difficult project to make because it requires lots of very precise measurements and a really well equipped workshop, with lots of tools. I am going to give you some details of how I built it but really is a project that can not be transferred on plans. I will include a couple of videos though of the finished product and the "gear box". Hope you like it and inspire you.
Tools and materials I have used:
  • Band saw
  • Hand saw
  • Radial arm saw
  • Mitre saw
  • Planer
  • Jointer
  • Various size chisels
  • Hammer
  • Drill
  • 6mm, 8mm and 10mm drill bits
  • Router
  • Sander with 80 and 100 grid sandpaper
  • Nail gun
  • Glue
  • 2mm copper wire
  • 25mm nails
  • Hole saws 45mm, 25mm and 20mm
  • Threaded rod
  • Wing nuts and bolts
  • Bearings
Here is a video showing the finished product and another one showing the gears!
Step 1: Making the Rotor and Blades
On the two first pictures you can see the rough plans I have made for the rotor and blades, I have used pine and 4mm plywood for the blades
I cut everything on the band saw sanded all the parts and glued all together as shown on the images above.
After the glue to set I used a rasp to form the wooden block and drilled a 8mm hole right in the center of it.
Step 2: Making the Base
For the base I have used two pieces 12 x 10cm (WxH) and a 45 x 15cm and glued them as shown on the pics. Before I glue them together I drilled two holes on the small pieces 3cm from the bottom. Those holes will accomodate the bearings and the shaft for the gears.
Step 3: The Stage
The stage is also a 45 x 15cm piece of wood. I also used some 1.7 x 1.5cm stripes of wood to make the stage towers for the lights...
Step 4: The Instruments
The first instrument I did was the drumset. I cut a cylinder using my 4.5cm hole saw and attached two small pieces of wood to form the bass drum legs. For the tom toms I used a 2.0cm and a 2.5cm hole saw. Attached them on the bass drum with some glue and my nail gun. A 2.5cm hole saw was used for the floor tom.
I designed the guitars on a thin piece of wood and cut them on my band saw.
Some thin pieces of wood were used for the cymbal stand.
(I am sorry I can not provide many details for the exact dimensions but really everything I did on this project was not planned.)
Step 5: The Instrument Players
Also here everything is made freehand. I used a 2.8 x 3.5cm piece of wood for the players body and then some dowels to form legs and arms. I wanted the arms of the players to ba able to move so I did not glue the soulders on the body, just used some 2.5 cm nails.
Step 6: The Gears
I have used a gear generator to design the gears,which I cut on the band saw. I have attached them on the metal threaded rod with some wing nuts.
Step 7: Using It
Once the stage was attached on the base everything was ready for painting.
Now we let the wind do the rest!
Thanks for watching and once again I am sorry I could not provide many details and measurements for this project. Hope I inspired someone to build their own!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    7 Comments
    My man cave need one of this powered by a diesel engine, Great job
    Great Job. Love the Band. Nice Instructable, easy to follow and sparked my interest in making a Whirligig - will start much simpler.
    Thank you very much. I am glad you like it.
    This is pretty frigen awesome.
