Rock-Dodo
3,443
222
16
Published
Introduction: Rock-Dodo
About: Technics/ arts and crafts teacher at a school for mentally disordered young adults.
After my last instructable about fake fossils on left over mosaic stones, i still had plenty of pieces of rock left over.Where there is plenty material, there should be an idea to use. So here are some decorative "stone age" Dodo's
Step 1: Materials
What you will need to copy me:
  • some copper installation wire
  • stones ( e.g. Flooring mosaic mats)
  • pliers
  • a utility knife
  • soldering iron
The soldering tools are a bit optional. You can do without although the result will be more vulnerable, and the bird might lose a stone now and again. Glue is another option but it will not easy to prevent stains
Step 2: Wire Preparation
Cut off a piece of wire. As each bird is made of one length of wire, be sure not to make it too short. One meter, 3,5 feet will do for most birds. With your utility knife peel one side of the plastic isolation away. After that it should be easy to peal the rest of the plastic off.
Step 3: Eyes
Find the middle of your piece of wire. Bend it in a sharp U shape fitting around a stone. Before putting the stone in, wrap the ends round a pencil to create two loops representing the eyes
Step 4: Head
Put a piece of stone in the U shape. On the under side of the head bend the upper wire down, and the lower wire up. See picture. Solder the two wires together at this point. You could do without soldering, but chanches are the stone will drop out at some point.
Step 5: Body
There is no wrong or wright way to bend the wire over the body. The less wire used, the more attractive the result will be, but make sure you secure the body stone in place. See the last photo for variations. Whenever the wires cross it's wise to solder, but strictly speaking not necessary. Bend the legs downward and for the toes start with a shap angle forward.
Step 6: Feet
To create birds feet with three toes forward and one back, follow these steps. It looks like a fairly complicated list of zig-zags, but it in quite easy in fact
  • First bend the wire forward, as shown in the body step of this instructable
  • At the end of the forward toe bend it backward
  • At the end of the back toe bend it forward, the leg should be in the middle.
  • At the second forward toe bend the wire again to the back
  • At the leg bend it forward
  • At the third forward toe back again. If you run out of wire skip this step.
  • Cut off the access.
Step 7: Stand Up
Bend all toes slightly down so the feet are a little convex ( round). Find the right position for legs and feet to keep the bird upright. Make friends!
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    16 Discussions
    Fricking ADORABLE!!!! Nice instructable!!
    Long thought extinct, a small colony of the species Rokado Cucullatus has been found surviving in a Netherlands polder recently...
    ITS ADORABLEEEEE
    I like it!!!! Hartstikke leuk ga ik zeker proberen.
    These are great! What beautifully simple and fun sculptures. Thanks for sharing.
    Very nice. A definite make this! Thanks for sharing.
    This is so simple, it's brilliant, nice idea and well presented
