Introduction: Rock Solid Skateboard Hanger From PVC Pipe
Looking for a way to hang a couple longboards up in the garage, we came up with this simple design.
This supports the board by the wheels, gets it out of the way and protects it from getting beat up.
Step 1: Material and Tools
PVC pipe - 3 inch diameter schedule 40, 10 inches or more. Can be solid or foam core.
Fasteners - 2" drywall screws, EZ-anchors or Tapcons.
Tools:
Table saw, miter saw and band saw. If you don't have these, a hack saw will do the whole job, it just takes a bit more work.
Drill press or hand drill
3/16 and 3/8 drill bits
tape measure/ruler
file
Step 2: Cut Twice
**** Be careful using power tools, use good judgement and follow all safety precautions please!****
Cut the pipe to length. A miter saw with a fine blade works great for this. Or a bandsaw or hacksaw. Cut to 10 inches long for a longboard hanger. Or 8 inches for a standard board.
Split the pipe in half lengthwise. A table saw or bandsaw works well for this. Or a hacksaw if it's all you have.
Step 3: Drill
Drill two 3/8 inch holes in the center of the pipe top-to-bottom, 4 inches apart. These will be the corners of the notch you'll cut in the next step.
Now drill two 3/16 inch mounting holes in the center left-to-right, one 1/2 inch from the edge and the second 1-1/4 inches from the same edge.
Step 4: Cut a Notch
Now, cut out a notch in the center for clearance for the trucks. This step is necessary Independent, Ventures and Gullwings. If you have Bear or Paris style trucks you may not need the notch, try it out with your board. On the side opposite the mounting holes, cut from the edge to the first large hole. Do the same for the second large hole. And then cut down the length between both large holes. A bandsaw or hack saw works well here.
Step 5: Mount It to the Wall
Now hang it up on the wall. Use a couple of drywall screws, 2 inch works great for wood framed walls, and screw it to a wood stud. Metal studs may require a pilot hole. Or use an appropriate fastener like a Tap-Con screw for concrete.
That's it! Good luck, I'd love to see a pic of your board hanging on the hanger if you'd like to post one.
