3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rocket Grill!
Step 6Side Tables
Side Tables
  • last photo ←
What's a grill without some workspace to hold your utensils, your plate of meat, and your favorite beer?
That's why the grill needs side-tables.
The water pressure tank used to make the top of the grill, included pipe connections in the sides. I purchased just a couple short sections of pipe  and elbows so that these could support the side tables.
I threaded in a horizontal pipe into each side, then a 90 degree elbow into that, A vertical pipe section then completes an "L" on either side of the grill.
Both side tables have a pipe flange going to a short piece of pipe SMALLER in diameter than the vertical side pipe. That way, the side table pipe sits INSIDE the vertical pipe. This makes it easy to remove the side tables for travel. Drilling a hole through both pipes allows me to slide a small bolt through, preventing the side table from accidentally rotating.
At first, I wasn't sure what I wanted to use for the top surface of the side tables. I dug through my pile of scrap/salvaged/recycled materials and found an assortment of stone, tile, steel, aluminum, and wood.
I simply set different pieces of materials on top of the side-arm pipes to see what looked good. In the end, I decided on a blue/green slate stone for the left side, and a steel deck place for the right side.
For the steel on the right, I just welded the pipe flange to the bottom of it, threaded in the short section of pipe, and slid that into the slightly larger diameter vertical pipe. A horizontally-drilled hole with a bolt slid through it completed that side.
The slate for the left was a little more work. The slate was rough and pointed, but it is a very soft stone. I experimented and found that RUBBING the edges of the stone with a cold chisel allowed me to shape the stone a bit and smooth the rough edges.
To attach the stone to the side pipe, I found some scrap metal about the right size for the bottom of the stone side table. I welded the pipe flange to the bottom of the metal and then glued that to stone with a tube of "JB WELD" adhesive.
Again, the pipe on the side table just slides into the vertical pipe on the side of the grill.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
283
Author:bennelson(300MPG.org)
Ordinary guy with no special skills, just trying to change the world one backyard invention at a time. See more at: http://300mpg.org/ On Twitter - @300MPGBen and at Ecoprojecteer.net
