Introduction: Rocket Hotwheels Cars
The objective to this project was to find the acceleration, instantaneous speed, velocity and the average speed of the car for five meters. The tracks distance oftwenty feet is broken up into 5 sections so we can find the speed at each one by getting the times of displacement between each photogate.This project goes over the do's and don'ts of making a rocket car, even though the mistakes were pretty fun to watch.
Step 1: Materials
Pen,
C motor,
Hotwheels,
Hot Glue,
Tape,
2x4,
angle iron,
wire,
drill,
Vernier photogates,
vernier software
Step 2: The Track
First you must acquire a twenty foot long 2 by 4. At each end mount a piece of angle iron, these will be the start and stop points for the car.
Step 3: Track 2
Once you have mounted the angle iron put a mark at 10cm, 1meter, 2 meters, 3 meters, 4 meters, and 5 meters. these are the points where the photogates will go to record the time.
Step 4: Track 3
Drill two holes in the angle iron centered and about an inch and half apart at each end and run wire from one end to the other keeping it straight.
Step 5: The Car
Find a hotwheels car that is in pretty good shape( will roll well). Depending on your car you may be able to mount the motor in the vehicle or if its a car you can just
Step 6: Car 2
glue the C rocket motor to the top with hot glue. Next get a pen and take it apart and cut the tube in half put your hotwheels car on the track in between the two wires.
Step 7: Car 3
Judge where you must put the pen tubes on each side of the car by the height of the wire and the width apart that they must be so it doesn't pinch the wire because the force
Step 8: Car 4
will keep it from moving. Once everything is glued on and solid wrap a piece of tape around the car and motor to keep the motor on.
Step 9: Don'ts
-Make sure you make the car wide enough the pen tubes don't get stuck on the wire because the balanced force and inertia will keep the car from moving
Step 10: Don'ts 2
The track must have two wires or the car will go where it wants and take out photogates
-Make sure pen tubes and motor are secure so they don't become projectiles
Step 11: Don'ts 3
-Use photogates in a shaded area or they won't work
-DON'T LET A DUMBASS HIT THE IGNITION BEFORE THE COMPUTER CAN COLLECT DATA
