Introduction: Rocket Launcher: Homemade
Step 1: Materials
3 pieces of paper
1 empty water bottle
Tape
Scissors
Toilet paper role
Coin (optional)
I did not use a coin as it weighed the rocket down and said no to flighing high
Step 2: Rocket
Tape up the top of the roll and place a piece of round paper down the opposite side so the rocket doesn't stick
Step 3: Tubes
To make the first tube you will have to come it slightly. Roll up the tube and then tape where air could escape but not the ends. The second tube just has to be straight but thinner in diameter than the other. It also has to be smaller.
Step 4: Turning Point
The turning point is a box that is made of paper. Tape up all if the sides so no air escapes make sure to get the corners. Then you will cut off two corners. You can then put a tube in there and seal it up with tape.
Step 5: Air Source
Tape the bottle to either tube on the end and secure with tape.
Step 6: Finished Just One More Thing
After firing the first time you have to blow the bottle back up. Just blow on the end of the tube and the bottle will expand.
