Remove these ads by
Signing UpStep 1Gather your tools and meet me in the classroom
You will need:
- A Hotwheel
- a rocket that is about any power lever from A to E but it shouldn't be too big comepared to the hotwheel
- A small funnel to attack to the car where the wire will pass through (here's something very important to know. You basically want to use something as wide as a regular drinking straw that you can steal from McDonalds. But if you use a straw it's kinda ghetto use the straw melts. So the best thing is to break an old pen and use the shell.)
- Hot glue or even super glue
- Anything else you can think of that wil attach the rocket to the car and attach the funnel to the car as well. (Duck tape is like a perfect attacher)
Here's like a basic way of putting this together for those people who enjoy instructions.
- Gather all the material listed.
- Try and use a hotwheel with a fairly flat surface. If that isn't going to happen then drill a hole through the windows of the car or just take them out all together.
- You can hot glue or super glue the rocket to the top of the car of your choice. With the hot glue being directly on the rocket my class has figured out the hard way that the rockets get so hot that they melt the glue and fly off the car. So if you can zip tie the rocket or get some duck tape to double in securing the rocket that is a highly stressed idea. (If you only go with glue then be sure to duck and cover when you set off that rocket because the rocket uses alot of force and heat when it goes.)
- When placing the funnel you want the funnal to be the same width throughout the whole thing because when the car goes you don't want their to be friction between the wire and the funnel. What you'll do with the funnel is place it on the car. There are a multitude of places where it can go. You can glue it ontop of the rocket, on either side of the car, or you can place it through the window if that is to your liking. Just make sure that the funnel is secure. (if you use the ghetto straws with some hot glue then the glue will melt it.)
When everything is secure then place the ignigtors in the car and get ready to launch your car on your track. Oh and just for fun check out how much your car weighs cause the car I used that successfuly got data for had a weight of 85 ounces.
What?? I'm not sure what you're trying to say there. Can you explain?
looks fun
