Rocket Stove Mass Heater With Soap Stone Tiles
10,347
148
4
Published
Introduction: Rocket Stove Mass Heater With Soap Stone Tiles
testing out a new rocket stove design!!
Step 1: First I Start With Welding Corner Profiles(30mmx30mmx3mm) on the Baseplate (500mmx500mmx5mm)
Step 2: Now I Can Place the Tiles(300mmx300mmx13mm) and Weld the Outer Corner Profiles
Step 3: Now I Have to Leave 2 Spaces Open for the Stove and the Outlet
Step 4: Putting a Tube (150mmx150mmx5) in the Hole to See How I Should Cut It Off
Step 5: The Angle Is 37dgr. So I Cut a Round Tube(dia. 100mmx4mm) 600 Mm Long
Step 6: I'm Lucky, the Stove Is Barely Fits Trough the Hole..but in the End All Is Good..
Step 7: Glue the Fire Cord
Step 8: Fill the Corners With Heatresistant Silicone
Step 9: Making the Chimney Connection
Step 10: Isolating the Chimney for Optimal Burning Temperature..
Step 11: Sprayed Everything in Fireproof Black and Mounted the Stove and Outlet..
Step 12: A Half Hour After I Lit the Fire, the Stove Was at No Place Touchable Anymore
Step 13: So, This Stove Had Burnt Four Hours Red Hot and It Didn't Budge or Break So I Think This Design Is Great, Next Thing I'm Going to Build Is a Similar Type But With an Oven and Also a Saunaheater, Will Be Interesting!!
Step 14:
changing the burner head into a vertically closed one, this gives me the advantage of not having an open fire(safety) and the wood feeds itself so less work..
it burns a lot better to, like a campfire becaus air can flow easely between the wood...
2 People Made This Project!
    • Spotless Contest
      Spotless Contest
    • Make it Move Contest
    4 Comments
    Any update on how this project has been since you made it?
    Any further changes or issues you have since faced?
    thanks.
    It looks great! Let us know how it results!!
    Looks very good. I'm now salivating as I wait for the finish.
    Looking good so far.
