Introduction: Rocket Stove by EAZEE
Picture of Rocket Stove by EAZEE
This rocket stove is a great welding project for beginners. You'll need to ensure you have access to a MIG welder and workshop tools. I have made several of these but, this version is easiest to make. There are several ways to do this and they way I have made this is not the most cost efficient, therefore, I have included another way in my step by step method.
A rocket stove is a portable stove fed by air and supplied with wood via a self-feeding chute on the front. Once alight it can be used to heat, cook food or boil water.
Step 1: You Will Need
Picture of You Will Need
You will need:
Tools and equipment; MIG welder, vice, band-saw, hacksaw, grinder, pliers, scriber, file, corner jig/mitre clamp (you can use a block of metal if unavailable), protractor for marking the 45 degree, a slide square and rule.
Materials:
4 x plates at 3mm x 100mm x 500mm long for the main chimney. (CR3 LCS)
4 x plates at 3mm x 100mm x 210mm long for the feeder. (CR3 LCS)
1 x plate at 3mm x 100mm x 70mm for the hinged cap. (CR3 LCS)
1 x plate at 3mm x 100mm x 130mm for the additional air intake. (CR3 LCS)
5 x 6mm x 80mm rod for the pan supports and for the hinged cap handle. (LCS)
1 x 6mm x 180mm x 180mm for the base plate. (LCS)
4 x 20mm x 20mm x 40mm long feet for the base plate. (BDMS)
1 x hinge to suit
NOTE: A much easier way to do this is using 100mm x 100mm x 3mm box section but I only had these materials at the time. Instead of using CR3 you can use hot rolled material which will be cheaper.
Step 2:
Picture of
Cut up your material ready to weld and deburr (if using box section cut one end of the chute section at a 45 degree angle that should measure 206mm on the longest edge and go to step 7).
Step 3:
Picture of
Tack together the main chimney. Always tack it together first and then weld. This will stop it from distorting. A good way to check if your assembly is square is to check across the corners as in the pictures above. Space your tacks about 50-75mm apart.
Step 4:
Picture of
Tack together your chute. Use the same method as with the chimney.
Step 5:
Picture of
Weld both the chute and chimney but, feather (grind or flatten off) the tacks before welding. This will stop any leaks or lumps from forming. As this is 3mm material, it is safe to weld downwards. Any thicker then consider welding in a flat position.
Step 6:
Picture of
Mark out where to cut the 45 degree angle on the chute.
Step 7:
Picture of
Cut off with bandsaw, hacksaw or cutting disc on angle grinder.
Step 8:
Picture of
Deburr all parts and offer up chute to chimney so you can mark out where it will sit.
Step 9:
Picture of
Cut out hole on the chimney using angle grinder with cutting disc or hacksaw.
Step 10:
Picture of
Fit additional air intake in to the chute at 30mm from the bottom. Stitch this in 6 places. I spaced this out using whatever I could find as you can see in the picture.
Step 11:
Picture of
Fit chute to chimney and to base plate and tack on. You'll need to mark out where the chimney/chute assembly will sit on your plate.
Step 12:
Picture of
Fully weld chute to chimney and to base plate
Step 13:
Picture of
Tack on hinge to chute and cap.
Step 14:
Picture of
Weld hinge cap assembly. If hinge is holed like mine was then just fill in the holes with weld (puddle weld).
Step 15:
Picture of
Add hinge handle and weld on.
Step 16:
Picture of
Turn on to top of chimney and space out about 40 mm.
Step 17:
Picture of
Bend pan supports in vice using a hammer.
Step 18:
Picture of
Weld pan supports on to top 4 corners
Step 19:
Picture of
Mark out, tack on 4 feet to base plate then,fully weld on 4 feet.
Step 20:
Picture of
Remove all spatter and clean accordingly.
Step 21: Fire Her Up!!!
Picture of Fire Her Up!!!
The first picture shows it going with the door open and the second closed.
Enjoy :)
Step 22: Your Turn!!!
You can change any of this for different materials or methods you may wish to use. Just because I have said that these are the tools you'd need doesn't mean that this can't be made without them. You can scale this up and make it larger or scale down to suit your needs. There are also many different designs out there that work the same way. Good luck! :)
DIY Hacks and How Tos (author)2018-01-05
That looks really sturdy. Have you made any measurements on how hot it gets?
Hi bud,
It'll boil a litre of water in no time. It is real sturdy too and kicks off great heat when you're camping.
About This Instructable
1,232views
25favorites
License:
Bio: Eazee1 is a welder/fabricator with 26 years experience, 13 of those as a lecturer/instructor. I love building and sculpting from metal. I use ... More »
More by eazee1:Rocket Stove by EAZEE
Add instructable to:
