3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rocket powered glider
Glue a micro rocket engine to a balsa glider. This is NOT a launch it entry, I didn't feel like doing the safety stuff, this was done to blow off steam between bouts of statics and statistics homework.
Step 1Wacha need?
A balsa glider
super glue
micro maxx rocket engines
aluminum tape
a spring from a pen
bamboo skewer
40 comments
Jun 26, 2011. 4:18 PMmrbones121 says:
are these the standard ESTES model rockets, or are these form some sort of fireworks?
Feb 28, 2010. 12:36 AMtrike road poet says:
A trick I've used is to mount the motor on a small sub frame of balsa, that slips over the nose of the aircraft.  The thrust of the motor holds the sub frame (against a small pin across the nose of the aircraft)  When the thrust quits, the motor will dislodge and fall away, leaving the glider free as the motor tumbles back to the ground.  On a larger glider, I put the motor in a paper tube on the belly of the model and when the ejection charge in the nose of the motor blows, it forces the motor out of the tube and the glider is free.
IF it survives launch, and IF the motor releases smoothly, the glider is high up and free. (be ready for a long walk!  A trick a buddy showed me was to hinge the rudder, add a pit of spring from a pen to force the rudder over, and a bit of thread to hold the rudder straight, (the end of the thread is across the inside of the paper tube ahead of the motor, and burn through on ejection.  The rudder swings over and the model goes into a wide circle and stays close to the launch area so its not so hard to recover.  Check out the control setup of old time gliders and you'll see the sort of thing I'm talking about.
By the way, GLUE the wings ON, or they will come off on acceleration!!!
Nov 11, 2010. 3:18 PMwoodchuck1800 says:
i have often thought about doing something similar to that, except i would fold back the wings on a rubber band sort of hinge giving the plane more of a rocket look, cut down on drag on power take off, when rubber band burns through wings take on normal position, and glides back to earth, a buddy of mine told me they already have something like this, well more fun to build it myself,
Nov 11, 2010. 5:22 PMtrike road poet says:
The folding wings idea is sound, but be aware that construction is important as the shock load of launch can cause problems. One thing you can do is hinge the wings and clip them together, held together by the clip which is held in place by the tube body of the rocket motor. When the boost motor burns out, the parachute charge 'ejects' it from the motor tube, along with the clip. The wings (spring-loaded) now flip out as the glider slows at apogee (high point) where there is the least wing load. Simple spring latches hold the wings fixed, and the glider now descends as a pure glider. There are some este rockets like this for a starting point.
The other idea is to have a wing angled back like a delta wing with low lift wing capability at launch (to rise straight up), and at apogee, the wings pivot forward (like an F-111) to make a high lift wing and make the glider fly slower but for longer distances. The wings could be extended by a mechanical unit (spring loaded) that pulls the two wing around the pivot point in a strong pull, when released. Its all about what you want to experiment with, but the concept is solid and do-able. Best of luck!
Sep 11, 2007. 1:02 AMSidney Floyd says:
Uh, isn't "Rocket powered GLIDER" an oxymoron?
Nov 11, 2010. 3:05 PMwoodchuck1800 says:
nice call Miko
should be rocket launch assist glider
Jun 1, 2010. 3:14 AMGreen Silver says:
You buy GLIDER from the store, then attach a ROCKET! So pedantic...
Sep 11, 2007. 2:10 AMpinski1 says:
Maybe more of Rocket-ASSISTED Glider?
Apr 12, 2009. 5:20 PMWyle_E says:
G. Harry Stine, in the old "Handbook of Model Rocketry", calls them boost-gliders.
Sep 29, 2007. 1:53 PMTycho7 says:
Rocket propelled aircraft would probably suit it better. Or Wooden-thingy-that-goes-really-fast.
Apr 12, 2009. 12:49 PMThelonelysandwitch says:
or better yet, a boring Tuesday.
Jul 31, 2010. 4:36 PMTSC says:
Nice!
Sep 30, 2009. 11:20 AMRe-design says:
I watched the video and didn't expect it to have power to fly. Boy was I wrong. How well did it fly after the motor quit?
Sep 14, 2009. 10:45 AMkm94 says:
Where do you get the balsa glider?
Apr 12, 2009. 4:24 PMkittycat123 says:
im with kicker109 it aint a glider
Sep 26, 2008. 12:16 PMtheXmaker says:
can't u replace the motor with a non-explosable firework rocket?
Apr 12, 2009. 1:18 PMmikemmcmeans says:
wait... fireworks dont explode?????!?!?!?!?
Mar 20, 2009. 9:42 AMwakojako says:
You should of called the Instructable how to burn your friends house down from across the road
ha ha ha
Feb 9, 2009. 3:47 PMdcutter1 says:
Back when I was a kid in the 50's we had these metal rockets that had little tabs that you put in them and then sealed it and had a little fuse that went through the exshuast hole. I hooked this up to a small balsa plane and it flew well though the rocket got red hot and burnt the bottom of it some, It landed in a tree but I was lucky and it didn't catch on fire. I was all out of fuel by then and never tried it again (most likely a good thing!!!)
Jan 2, 2009. 3:59 PMelectronicfreak22 says:
Does anyone know where to buy Micromaxx engines in Winnipeg (Canada)?
Jan 2, 2009. 4:43 PMSaint_Awesome says:
I seem to remember Toad Hall Toys had all kinds of estes rockets, probably engines too.
Jan 2, 2009. 8:49 PMelectronicfreak22 says:
Yeah.. I have some estes engines.. I just find the MicroMaxx engines interesting. Does anyone know how to get the fuel out of a estes "A" engine.. and what to put it in to make a rocket similar to the size used?
Nov 6, 2007. 5:21 PMthemasterpyro says:
nice but wouldnt the rocket engine put too much stress on the glider or set it fire(WOOT!!! BURNING FRAGMENTS OF BALSA GLIDER FALLING ALL OVER THE TOWN SETTING IT ALIGHT!!!!WOOTAGE!!!!)?
Jan 2, 2009. 4:20 PMPlasmana says:
What is the problem with fireworks that are made of paper and explosives?
Sep 14, 2008. 8:18 PMkicker109 says:
if it is rocket powered then it isn't a glider
Aug 7, 2008. 6:07 AMpower says:
can I use foam gliders?
Jan 27, 2008. 9:32 AMsalaok says:
dude that is so funny i put like ten small motors on a remotecontroled plane i got for like $20 and launchesd it mid flight it was coll becuse i launched it just before it stalled and it shot up but blew the wings off.
Aug 7, 2008. 4:25 AMevilgenius 398 says:
:D hahahahaha
Sep 11, 2007. 12:11 PMbtop says:
Cool, I like!
Feb 2, 2008. 5:32 AMMayolaTikaka2 says:
you mean it is cool i have not tried it
Nov 30, 2007. 9:25 PMX_D_3_M_1 says:
did u burn ur house down?
Oct 19, 2007. 3:54 AMjdyahoo says:
I did that when I was a teenager. It went straight up, ripped the wing into pieces and came straight back down onto the hood of a car. I got what was left of it back after the attention had died down about half an hour later.
Sep 12, 2007. 1:03 PMfd93 says:
That works but to launch it it tkes a metal rod and very carfull balencing or zipline it
Sep 11, 2007. 12:43 PMWard_Nox says:
or you can just crazy glue a ESTES engine (or two if you have the multi engine launcher) to the under side a guy at my in Highschool rigged a toy car with one as long as you don't block the recovery charge theres a good chance the plain will survive (unlike his car)
Sep 11, 2007. 5:37 PMWard_Nox says:
Ive never used micromax b4 so I'll take your word for it heh if u fix flash cotton to the front of the estes it'll not only explode but do so fantasticly (consider this idea listed as Not Liable btw)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
