Introduction: Rocket Stove Manufacturing Waste 40 Minutes.
Picture of Rocket Stove Manufacturing Waste 40 Minutes.
At a time when you had to use the stove, near rectangular pipes were made ​​of iron sheets, container and some of the same material. With these tubes was made rocket stove for 40 minutes.
Step 1: Getting Started
Picture of Getting Started
First prepared container. For this side container cut a hole under the pipe.
Step 2: 2
Picture of 2
Pipe cut the desired length. In that part, which will be located in the tank, made hole for the fire. Made of tin ash pit.
Step 3: Assembly.
Picture of Assembly.
Gathered all the stove rocket.
Step 4: Testing
Picture of Testing
Rocket stove has been successfully tested. Water began to boil for 5 minutes. Stove to work you need a little firewood. Lit a long time, gives a lot of heat. The stove was made for a single use, from waste material. She worked her, and I threw it away. Although it is quite efficient. For the manufacture of stoves used tools: 1) The angular-sander 2) Axe 3) Pin. Thank you all. :)
About This Instructable
4,951views
21favorites
License:
More by cherkes:Rocket stove manufacturing waste 40 minutes.Sharpener from HDD
Add instructable to:
