RocketBot Line Follow Sensor by Chris the Carpenter
Step 8: Mounting and Use
Mounting
The Line Follow Board mounts to the RocketBot robots via (2) 40mm stand-offs. Go ahead and put them on now. The mounting holes closest to the pin headers is for regular line following, while the holes closest the sensors themselves is for mazes. Stick 'em on and snug up the screws --no need to go "red face tight" here, just snug.
At this point, you are ready to mount the sensor board to your robot and connect the wires. Each robot (Picaxe, Arduino or Propeller) will be slightly different so I will not cover the wiring here. Information on connections and some example code can be found at:
http://www.rocketbrandstudios.com/line-follow
Enjoy.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
