Rocksmith Control Pedal (Stompbox style controller) for XBox 360
 by smokeandlights
Featured
Step 3: The Enclosure
I got inspiration for the techniques I used in crafting this enclosure from this instructable by Improbable Construct: http://www.instructables.com/id/Homemade-Mini-Press-Brake/
I started with a very basic form of that press brake, knowing that I would not need very sharp angles. really, I just took 2 equal lengths of 2x4, and put them together with 2 heavy duty hinges that I had lying around. I used a piece of 1x4 cut to the same length as the gap between the hinges to clamp my sheet metal in place.
I used a sheet of plain 22 Gauge steel from home depot. It measured 12"x18",
I measured out and marked both long sides of the steel. I wanted the front to be 2" tall, the back to be 4" tall and the top to be 8" from front to back. I also left 1" to curl under the bottom at the front and 1" at the back. these lips would serve as a place to secure the sides.
Using my makeshift pressbrake, I bent the sheet metal into shape. I had to fold the back a little extra by hand, as I could not achieve a 90+ degree bend with my rig. This was easy enough to do.
Once I had the metal bent, I traced the shape onto some 1x6 maple I had from another project. I cut this out with a jigsaw, made a second copy, and sanded them until they fit just right. I drilled pilot holes through the metal and put drywall screws into the sides to hold them in place.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
