3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rodent Resistant Composter
Step 4Fold Compost Basket Together
1. In order to make the bottom of the basket the tabs need to be folded so that they overlap each other by 30 degrees for our design (or whatever degrees works for the number of tabs you're using). Use the template to check that each tab is overlapping the correct amount.
2. Clip the tabs in place using 2" pieces of 12 gage mesh. First poke them through the mesh then twist them, then use pliers to bend them over themselves to create a good tight pinch.
3. Fold each following tab in to position using the template as your guide. Secure each tab as you go with a piece of wire.
4. The shape looks absolutely beautiful when the structure is completed.
Note: zip ties work great if your hands get tired of dealing with the wire.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:mollyd(Cloacina Project)
Cloacina is the Roman Goddess of the sewers, we've enlisted her help to develop ecological sanitation solutions for the urban US.
