loading
Step 2: Burn Holes and attach battery
There should be 3 holes in the plastic, not 2 like the picture. I burned through the plastic using my soldering iron - a horrible idea, but there was nothing else around. it works.
Insert batteries into the battery pack. Tape it to the bottom of the plastic lid and loop the wires through the holes. The positive wire from the battery pack (usually red) should stay on the top side of the plastic, while the negative wire (usually black) should loop through the second hole back to the side with the battery.
Using a tape measure, make a small mark on the edge of the lid about every 2.25 cm (But it will depend on the circumference of your lid and how many LEDs you have. To figure out how often to make a mark, do the following:
Circumference of the lid / Number of LEDs
This is purely aesthetic; if you don't care about your LEDs being evenly spaced or just want to eyeball it, the device will still work.
what is that plastic case for?
it is like a plate with a top cover
With a little imagination, this could be be used a lot of places. How about leveling a table.
it's amazing
That's great! I can think of a perfect application without changing anything: Teaching This is so easy and fun, a bunch of elementary school kids would love it! And they would learn about electricity, physics, and recycling without any boring textbooks! You're the best, Kyri!!!
hehe, try attaching it to the rims of your car : )
wow i can all most tell how to make this by look at the 1st pic very good
I'm trying to think of a practical application for this. None come to mind, but it's really cool, anyway. Instead of capacitors, what if you used James' idea of aluminum foil, but put a coating so that the resistance of the foil changed from the center to the edge. That way, when the ball was right by the LED, it would get full power and be bright, but as it rolled away, there would be less power and the LED would gradually dim.
Practical application = a bomb detonator<br/>&quot;Don't pick that up!&quot;<br/>&quot;Why not...&quot; BOOOM!!!<br/><br/>Not that I am saying anyone should do it just letting you know. You could also use it as an alarm with modifications. By the way great instructable, what about high powered LEDs? <br/>
It woud be nice to add a capacitor for each of the diodes to make it fade out slower.
Oh yeah--super idea there. How did you come up with this? This is great!
Basic electronics knowlege <sup>_</sup><br/>
Oh, I guess I meant, I think adding a capacitor is a super idea and 2)Kyri-how did you come up with this? Anyhoo . . .
lol. To add capacitors you need a more powerful battery so it will charge faster, otherwise you wouldnt get much effect. You could also just widen the contacts on the LEDs with aluminum foil tabs.
Duh! That's a great idea, too!
thats what I specialize in :)
(great ideas that is)
Keeping it simple, I like your style!
You know with a little more development you could use this as a tool for say something like a drill. It could indicate if you need to raise the bit or lower it when drilling horizontally. Or in a drill press to obtain a plumb setup.
Nice Instructable! This also could be transformed into a super-duper tilt sensor!
This is a great idea! I can easily see how it could be incorporated into a pet (or children's) toy.
Or.. dare i say it?.. a Trip toy.. Not that I do drugs or anything..
Awesome job! Very clear, fun, and, most importantly, easy! Keep up the good work.
This looks really fun! You should add a 50 ohm resistor in series with the battery to limit current to the leds to 20Ma- that way you won't burn them out.
Yeah, i thought about that ...haha, I guess I figured the ball would only be touching it for a short while so it wouldn't matter, but it might be a good idea.,
Agreed with Jeff. This really has potential! Adding a capacitor to the LEDs for a "fading" effect would make the illumination of each led more noticeable Also, try and make it USB powered! Every thing's better with USB ;P Nice Job!
Cool nice job!
About This Instructable
10,891views
45favorites
License:
Bio: ECE student at Carnegie Mellon University.
More by Kyri:Color Detection Using RGB LED Your own Operation Board Game Roly Poly LED
Add instructable to:
