Fantastic! I was looking for instructions to make window quilts a couple of months ago. Now without hunting I came across yours... thank you! I don't staple like l8nite, but I have been known to nail them across the top. Good thing I have no one to yell at me! Yup, they do make a huge difference. Thank you yeehacmh. A 5 for sure!
Dang, I wish I'd seen this a couple weeks ago when I bought new shades for my windows! This was exactly what I was looking for but I ended up with something only meeting a third of what I wanted! I may have to convert the new hangings using your method! Nice job!
My windows were so cold I taped attic insulation up, but now I will work on making these shades for next winter. thank you for a solution thats is both visual and works. Just to add maybe these would make great given as gifts.Thank you for your work
Thanks Joy... I made these out of straw floor mats for my windows years ago. They worked good. I figured, why not make them even heavier with stronger string. It worked out perfectly. Stay warm !
I have made these shades, they work great. BUT you don't have to use the tomato stakes or any piece of wood on the folds. You can machine sew a stitch across the fold place and place your rings a bit closer together, every 10" or so and the fold occurs naturally when you pull in the attached strings as you instructed. It does help to have a dowel or some type of weight in the bottom hem of the shade, as this helps it drop evenly when closed.
Thank you bstPip, I was worried about the weight of these folds and I remember reading that you "can" do without these battens, but you may be sadly disappointed in the sag of your shade pleats without them.The battens will help keep your fold lines clean and neat. As it is, the shade is heavy and falls easily. Appreciate the 5 Stars, never got many of those before ! ( except from close relatives ) The bottom could use a batten. A small adjustment is needed at the corners when lowered. Rather than more cutting and sewing, I was just going to hot glue an aluminum screen frame-piece along it. It's doing really good though.
Please see my Thumb Drive Container RAM BOX with built-in powered reader. This project was built almost entirely from dead computer parts . The addition of a 52-in-one card/flash drive reader was needed to complete this wonderful awe inspiring, almost jewelry enhanced, ark of the covented. Also, my Instructables Irfanview, a great media helper. Part 1 How to install, set up and change BMPs to JPEGs. I've been using Irfanview for years and it constantly amazes me. It's free and it's simple but it can be complicated too.
The tomato stakes are actually the battens. The 1 and 1/2 inch lumber is for attaching the shade at the top. Dowels were me first choice for battens but I had a few tomato stakes laying around and they had points on them. I cut them with a pipe cutter and some with a hacksaw. The pipe cutter was much quicker. When the battens were installed, I had to go back and pull them out and trim them so they cleared the walls better.
I was just thinking of the weight and the fact that my tomato stakes rust eventually - I live in a humid climate. But I'm sure there are lots of alternatives. Still a great idea - good work!
Thanks zanne101 ! These stakes are thin metal and hollow. They're plastic coated and last several seasons. They're about $1.50 apiece for a 48 inch stake. They probably weigh less than a comparable wooden dowel. The nice thing is..if needs be, you can cut away the plastic and thus cut down on its size and weight. I remember seeing them when they had gotten old and the plastic was coming off.
Great "ible" a bit more involved than my stapling the quilt to the window frame, your way probably helps keep the woman of the house from screaming, throwing things and calling you names that no one else could get away with calling you....
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
These shades can make a really dramatic difference when it's cold.
Be patriotic and vote everyone!
I give this 5 stars!!!
I love this idea!
5 stars!!!!!!!!!
It deadens the sound of the train blowing it's whistle late at night too.
Emm
Couldn't you use small diameter dowels instead of the 1X1 1/2 pcs of wood? Dowels are usually very light.
