Romance pants are a pair of pants that dims the room lighting and raises the stereo in relation to the fly zipper being pulled down. Of course it does not stop there. The romantic coup de grace involves electronically ignited candles triggered by the unbuttoning of the waist button. This subtle sensual assault is sure to shock and awe any prospective partner into ecstatic submission. As the evening progresses, this smarty-pants technology will undoubtedly to set the mood to the appropriate level of 'getting it on.' Romance pants are definitely where the future lay.
This project was made by Team Instructables for the Creation Challenge. Principle innovators include Amanda Ghassaei, Audrey Love, Jake Rogers, and Randy Sarafan. Team leadership and moral support provided by Mike Warren. Heckling and wisecracks provided by the rest of Team Instructables. A special thanks goes out to Erin Sharpe for a superb acting job and Greg Johnson for amazing handcrafted candle holders.
Step 1: Go get stuff
(x1) Ability to attract future make-out partners (this is essential)
(x1) Kissing skills (this is optional)
(x1) A Bullduino (or Arduino)
(x1) Arduino
(x2) Arduino Wireless Shields
(x2) Xbee modules
(x1) 7805 voltage regulator
(x1) M-type power plug
(x1) 8" x 6" x 3" project enclosure
(x2) 3" x 2" x 1" project enclosures
(x1) 12" x 18" x 1/8" acrylic sheet
(x10) 6-32 x 1" nuts and bolts
(x4) 4-40 x 1/2" nuts and bolts
(x1) 4-40 x 3/8" nut and bolt
(x1) Lamp power cord
(x3) Standard power sockets
(x1) SmartFan AC-VX Fan Controller
(x1) 9V battery holder
(x4) 9V battery connectors
(x4) 9V battery
(x1) Small round PCB
(x1) 0.1uF capacitor
(x1) 10uF capacitor
(x2) 5V reed relays
(x4) 1/8" mono panel-mount jacks
(x2) 1/8" male-to-male stereo cables
(x1) Stereo with Remote
(x1) IR LED
(x1) 38mhz IR receiver
(x1) 40 AWG nichrome wire
(x1) Box of strike anywhere matches
(x6 - 24) Mood-setting candles (scented preferable)
(x2 - 10) Candle holders (with hollow bottoms)
(x1) Flattering pair of pants (must be clean)
(x1) A couple feet of conductive thread
(x12) 10K resistors
(x1) Shrink tube
(x1) Red and black 22 AWG wire
(x1) Assorted zip ties.
Step 2: Mod a wireless shield
Thus the first order of business, was lowering the profile of the wireless shield so that it did not make the buckle stick out in front quite as far.
We trimmed the header pins down roughly 1/8" and entirely removed the ICSP socket from the shield (it turned out to be unnecessary for our needs).
The shield then sat flash with the sockets on the Bullduino.
Step 3: Mod the Bullduino
The Vin pin on the Bullduino did not appear to be wired up. The V+ soldering pad on the Bullduino did not appear to be electrically connected to the power coming off of the USB port. We were unsure what the V+ soldering pad was rated for, and were mildly intimidated to figure it out, as we only had one Bullduino to work with.
This left us with two options. We could either feed a +5V power supply through the 5V socket or add a wire to the +5V pin on the USB port. Neither option was particularly appealing and there was not much consensus. Some people thought we should just send it into the 5V socket and not mess around with soldering to the tiny pins on the board (as they doubted my ability to solder to tiny things). Whereas, other people thought the USB port probably had some sort of buffering to protect the Bullduino from spikes and voltages from the power supply, and thus this was the best place to connect and input voltage. We were at a bit of a standstill
Ultimately, I (i.e. Randy) waited until no one else (i.e. Amanda) was paying attention and soldered it really quickly to the USB pin. The problem was thus solved while Amanda was distracted by her "Beat Slicer." This was one instance in which the repetitive looping of Beach House songs proved useful to the team.
Once the power input extension wire was soldered into place, it was then just a matter of epoxying it down in a few spots to keep strain off the joint, and prevent it from ripping loose. I did not cover the solder connection itself with epoxy in case I needed to get in there for some reason and fix the connection.
Step 4: Zipper Potentiometer and Waist Button Switch
We started by sewing in half of a snap with the conductive thread, this snap becomes a lead you are able to solder the resistors and wires to. To create a ground rail for the zipper, we stitched in a line close to the zipper, then ran chutes between some of the teeth that will make the teeth on the metal zipper conductive, and make contact with the other side of the zipper, when the zipper is closed. Next, sew in the 5V rail, and your resistors.
For this part, we worked in steps, after each resistor was sewed into place, a chute was sewn in between the corresponding zipper teeth. It was helpful to count the teeth between steps, to make sure that you will make contact with the other side. The
After the zipper potentiometer was sewn into place, we turned the waist button of the pants into a switch. We embroidered the edges of the button hole with conductive thread, and also wrapped the post of the waist button with thread. Luckily, the pants had a copper button, and we were able to solder a wire directly to the button post. The button post was wired to the the 5V from the Bullduino. The button hole was connected to a 10K Ohm resisted ground wire, and a signal wire that goes to digital pin 02 on the Bullduino.
Step 5: Electric ignition candles
We drilled two holes through the candles using a drill press and heat gun and fed two wires through the holes so that only a small bit of copper stuck out from the top. Then we lit the candle to allow some of the wax to melt away. We wrapped a ~1" piece of nicrome wire between the two exposed copper wires so that it passed near the candle wick. We connected the wires to a 9V battery to test the connection with the nichrome wire (when voltage is applied to the nichrome wire it will glow red). Then we used a razor blade to remove the accelerant from about 5 matches and sprinkled the dust all around the nichrome wire.
And here's what happens when we connected the nichrome to 9V again:
Step 6: Stereo remote hack
The full instructions for doing this were actually posted in a separate Instructable. To do this yourself, simply visit Clone a Remote with Arduino and follow the directions.
Step 7: Wireless communication
The Bullduino should be loaded with the following transmitter code:
The Arduino for the receiver box should be loaded with the following code:
When both are programmed, make sure they are powered down and attach the wireless shields. Make certain that the microswitches on both of the the shields are toggled to "micro."
Step 8: Build the main controller
Wire the three outlets together in parallel and extend two 8" wires off of each connection on the power outlets.
Mount the outlets to the front panel using nuts and bolts.
Mount the SmartFan controller, Arduino and 9V battery holder to the bracket acrylic base brack with nuts and bolts.
Drill two 1/4" holes side-by-side that are centered, about an inch apart, on one of the 6" x 3" sides of the box. Drill another 1/4" hole centered on the other side of the box.
Drill a 3/16" hole in the center of one of the 3" x 8" side of the box.
Insert the wire from the lamp cord through the singular 1/8" hole about 12" into the center of the box and knot it so that it cannot be pulled back through.
Wire the lamp cord to the "W" and " "B" terminals on the fan controller. Wire the two cords coming off the front panel to the "FW" and "FB" terminals on the fan controller.
Connect the Arduino's pin 3 to the 5V port on the fan controller, and then connect the Arduino's ground to the "com" port.
Solder a 9V battery connector to the M-type power plug such that the red wire goes to the center tip. Remember to slide the cover onto the wires before you solder it so that you can screw it back into place when you are done.
Solder the two barrel connection tabs on the mono jack together and extend a 6" black wire off of one of them. Solder 6" a red wire to each of their signal tabs.
Solder a 6" red wire to the positive lead of the IR LED and black wire to the negative lead.
Insert the component bracket snuggly into the bottom of the case.
Mount the jacks in the two 1/4" holes using their mounting hardware.
Push the LED through the 3/16" hole and hot glue it in place of necessary.
Connect all of the loose black wires to ground on the Arduino.
Connect the red wires from the jacks to pins 8 and pins 9 respectively.
Connect the red wire from the IR LED to pin 13.
Attach the connector to the 9V battery, plug it into the Arduino, and secure the battery in the battery holder.
Finally, put the lid on the top of the box and fasten it firmly place.
Phew! You're done.
Step 9: Make the belt controller
The one "tricky bit," if you can even call it that, is regulating the 9V source to a steady 5V supply for the bullduino.
This is accomplished with a 7805 regulator and some filtering caps.
To make the regulated supply, get a small round prototype board and solder the 7805 regulator to it. Connect a 0.1uF capacitor between ground and 5V. Connect a 10uF electrolytic capacitor between ground and 9V (watch the polarity).
Attach a 9V battery snap to the Vin pin and ground. Respectively attach 6" of red and black wire to 5V and ground.
Put the belt between the Arduino and the wireless shield, such that the shield is right up next to the belt buckle.
Zip tie the voltage regulator PCB to the side of the belt.
Stick the 9V battery in your back pocket. This isn't particularly elegant, but it works.
Step 10: Make the candle controller
We gave each grouping of candles its own 9V supply to ensure they were getting as much power as possible, and ensure each one triggered when voltage was applied.
To build this, take your 3" x 2" x 1" project enclosure and drill a 1/4" hole in the center of each 1" x 2" side.
Mount a 1/8" audio jack in one of these holes. Connect the the pins from the audio jack to the coil pins on the relay.
Connect the 9V supply to one of the source pins on the relay. Connect a 6" red wire to the other pin.
Pass the black wire from the 9V power supply and the red wire from the relay out the other hole in the case.
Make sure the battery connection is good, and seal it up.
Build one of these for each grouping of candles that you want triggered.
Step 11: Set it up
Strategically place the candles around your room to maximize ambiance and minimize fire hazard (the flames can ignite very explosively). Plug in the candle relays to the main controller box using a long audio cable and fill the candles with match head dust.
Place lamps around the room and plug all of them into the three prong plugs on the controller box.
Put the pants on and the belt with Bullduino. Wire the Bullduino into the pants as specified in Step 4.
Step 12: Profit!
However, bringing home a lover is probably going to be most challenging part of this project and primarily relies on your skill and cunning.
Fortunately, you have a killer Bullduino belt buckle. If this does not gain the attention of a potential make out partner, we don't know what will.
So... Go get 'em tiger!
Once you get them back to your lair, just let the romance pants work their magic, and always wear protection.
Visit Our Store »
Go Pro Today »
vimeo.com/2566796
vimeo.com/2218189
if you were at all inspired by my work I would appreciate credit and a link to my site: lynnwashere.com
thanks.
Getting a jelly bean stuck in your nose from the wrong end really makes your eyes water!
Excellent choice of music, too.
RIP, Donna.
But I worry about that zipper. Does it have any potential to give electric shocks to the wearer? :o
ouchie!
I have no intention of making these as my skills are sufficient and gals like guys with skills, but I definitely dig J Dilla as the soundtrack for the instructable vid.
Dilla says go, Keep up the good work.
your doing it right.
