3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Romaurie-Effect": inverted aquarium in shallow base aquarium.
\"Romaurie-Effect\": inverted aquarium in shallow base aquarium.
This details the design and set-up of a vacuum-filled aquarium.
Step 1Draw a plan of the aquaria with dimensions for the glazier to follow.
I've chosen a relatively simple inverted aquarium that sits in a shallow base aquarium as opposed to the "tunnel" that links 2 aquariums with a vacuum-filled "water-bridge".
I've enclosed drawings that you can either have a glazier construct or cut and you assemble.
15 comments
Jan 23, 2008. 11:16 AMrandofo says:
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
Jun 3, 2011. 9:59 PMpaqrat says:
It looks to me like you have reduced the surface area available to oxygen exchange. If this is the case the aquarium would probably support fewer fish optimally.
Jun 6, 2011. 9:35 PMpaqrat says:
I understand. The video made it much more clear. It does make for a very visually interesting aquarium. Its been many years since I have had my aquariums up and running. I hope one day to get at least one of them going again. My "hacks" of the systems were a great deal less ambitious. One simple one I tried that seemed to have success was placing an external filter on the side rather than the back. My reason for this was the idea that placed on the back the water flows into the tank where it soon collides with the front glass thus creating an unnatural (to the fish) turbulence. By placing the external filter at one end the water enters the tank and flows to the opposite side creating a current. I noticed soon after that many of the fish would position themselves in the most forceful part of the current. I assumed they benefitted in some manner from this.
Aug 8, 2008. 11:31 AMbudsiskos says:
this is incredible. i am so making one
Aug 8, 2008. 7:19 PMbudsiskos says:
actually i read a little deeper into it and would prefer not to have to use a valve. so i decided to just make a smaller one and submerge it in a bucket or bathtub until it was full then pull it out so that it has a more natural vacuum effect. however, i really did like the concept and may consider doing this the correct way in the future. also it would really help if you posted all the videos, or at-least the links here to this page.
Aug 10, 2008. 8:34 PMbudsiskos says:
about how long does it take until you need to vacuum it out again
Aug 11, 2008. 1:59 PMbudsiskos says:
how do you change the water?
Aug 8, 2008. 9:43 PMbudsiskos says:
the same idea could be used to make a hero's fountain
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:romaurie
refrigeration engineer; M.O.D. trained; from Christchurch Hampshire[before it was removed to Dorset] moved to Eilat, Israel in 1987.
