Salt Lake City, UT received over 4 feet of snow during the first 10 days in 1993. Residents were out in mass, shoveling the heavy accumulations of snow from roofs, in anticipation of more storms to come. In many cases, the danger of falling from slippery roofs proved to be greater than the risk of collapsing roofs.
By January 10th, fall injuries had flooded emergency rooms. The Salt Lake Tribune warned Clearing Snow From Roofs Is Pitched With Dangers.
This snow removal tool is a product of that crisis. It was developed to provide a way for removing roof snow without having to climb on the roof.
KSL Television spotlighted this tool on the 10:00 PM news on January 10th. The newscast was followed up by a news article in the Deseret News on January 12th, which gave brief instructions on how to construct the snow removal tool.
http://www.youtube.com/watch?v=Hsp-IjueZ5M
Subsequent articles by the Deseret News during the next few days made the following observations:
Impressed by a roof-clearing contraption invented by a local man using PVC pipe, Salt Lake officials have begun building and lending the devices to residents.
Salt Lake Mayor DeeDee Corradini said..her..staff had made 30 of the snow removers and were planning to make up to 60 more. People are starting to make these all over town, Corradini said, They really do work very well.
Thompson didnt just cast worried glances at his roof. He whipped up a gadget that looked a little like something from outer space. It cleans a roof lickety-split without the home owner endangering life and limb by climbing up icy shingles. The invention caused a run on PVC pipe at local home-maintenance stores.
By week's end stories about how to remove roof snow safely were a staple in all media. A recurrent piece was on how easy it was to use a plastic pipe contraption. Deseret News followed up on television reports of how a householder created such a device for under $20.
This roof snow removal tool may take you a couple of hours to build. It may spend years in idle storage. But, when you need it, you are really going to need it and so will your neighbors. Share the tool around. All it takes is a little duct tape and plastic sheeting to make it as good as new and allow you to be prepared in time of need.
ROOF SNOW REMOVAL TOOL - PARTS AND TOOLS REQUIRED
PARTS AND SUPPLIES LIST
(Quantity) Item *All PVC pipe and fittings are Schedule 40, slip
(6) 10' sections of 1" PVC pipe*
(1) 1/2" rigid copper pipe, 18 1/2" long
(2) 1/4" diameter steel rods, 18" long
(2) PVC tees*, 1" x 1" x 3/4"
(1) 3/4" PVC pipe, approximately 16 1/4" long
(2) 1" PVC elbows*
(1) 1/4" dia. steel rod, about 21" long (Cut finish length in step 20)
(1) Flat piece for front foil, 2 1/4" wide by 16"long, made of 1/8"
Plexiglas, sheet metal, masonite, or other durable material
(1) 10' length of plastic sheeting 18" wide to use as an apron for snow
to slide on. May need to be longer, depending on length and pitch
of roof. Flat poly sheeting, about the thickness of contractor
garbage bags (3 to 4 mils), works well.
(4) 1" PVC connectors*
(6) #6 pan head screws, 1/2" in length (Phillips are easiest to install)
(1) Silicone glue (small amount)
(1) PVC glue (small can is sufficient)
(1) Roll of duct tape (You can never have too much)
TOOLS REQUIRED
Item
Hack saw (A pipe cutter can be used instead, on pipe cuts)
Vise
Electric drill (Drill press preferred)
5/8" wood bit
1/4" drill bit
1/16" drill bit
Screwdriver
File
Scissors
Remove these ads by
Signing UpStep 1:
Mark the 1" pipes with an "A" on one end and a "B" on the other end.
Mark an "X" on both 1" pipes at a distance 1-1/2" from the "B" ends.
![Snow Survival Shelter [must have deep Snow]](http://www.instructables.com/files/deriv/FW6/JS4B/GYGGIY1R/FW6JS4BGYGGIY1R.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
This was a new word for me..."Chamfering: A cut that is made in wood or some other material, usually at a 45° angle to the adjacent principal faces."
If I understand your comment, the uprights make two chamfer cuts in the snow.
Thanks for the comment,
Grandpajoe
Thanks for the ingenuity
Grandpajoe
Thanks Strider...Good catch. I always try to make my mistakes in triplicate so that at least one of the three prersons seeing it will catch the error and help me correct it. In this case it took over 7,000 views before it was noted. I have now made the change to show the measurement as 3-1/2". As you have seen, this exact measurement is not very critical, but it should at least match the illustration.
Thanks for the insight
Grandpajoe
Thanks again and good luck,
Grandpajoe
