So we made one... for a couple of bucks..
What you need;
>Car with permanently mounted roof rails (picture 1)
>Two boards - wide enough to span your roof rails with 2-4 inch's extra on each side x 1 inch thick.
>padding material - we used a roll of hessian tape - carpet would work
> Four U bolts, with nuts, washers - dimensions;
-wide enough to fit around your roof bars
- tool enough to pass through the boards and around your roof bars
>pencil
>square
>ruler
>drill
>drill bit just bigger then u bolt thread
(picture 2)
Remove these ads by
Signing UpStep 1Step 1
>Take your first bolt, remove the nuts and washers and pass it under the roof rail in front of the board.
>Use the square to draw to parallel lines across the board for both threads of the U bolt.( picture 3.1)
>Then from the end of the board, use the square to draw on line to intersect at 90 degrees (best halve the width)(picture 3.2)
Repeat for each U bolt - then drill the holes.
To help keep the nuts on, try a touch of superglue on the bolt threads.
