3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Roomba costume
Step 4Cut out pattern pieces
Now that you've got all the pattern pieces traced onto the fabric, you can start to cut. Now would be a good time to double check that you have everything laid out correctly, with the grain of the fur going in the right direction. Measure twice, cut once, etc.
Some of the pieces will need some extra room outside of the traced pattern. This is called the seam allowance. You can leave as much seam allowance as you want, but I usually go with one-half inch. In this case, I have marked the areas that need a seam allowance of some sort with a thick black line on the pattern reference. On those sides, cut one-half of an inch outside of the traced pattern line.
Only applicable if you are using very thick fake fur: Go back and trim the fur from the seam allowances. This will keep the seam from being too bulky later on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:egoodman
