3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Roommate Blocker 1.0
Step 2The Run Down
The Run Down
The smaller your room is the easier this project will be. I used a sliding door so that I could minimize the amount of open space in the frame. I also did not want to drill into the walls so most of the wood framing is completely wedged into tight spaces. There are only about three or four drill holes in the wall space of about 5'x8'.
There are only three major steps to this project:
Build a frame.
Put up the drywall.
Mount the door.
This seems simple, but dorm rooms are never perfectly square, so you will need to adjust because nothing is really straight. This wall obviously does not have to be perfect since it just intended to split a room into two, but the door will slide better if the wall is straighter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:Romado12187
