Step 3Building a Frame
Drill the guide hole, and mount and drill in the first beam. Drill another hole if you need to, this is the anchor of the wall, everything else will rely on the strength of that connection in order to support the weight of the door. You can drill as many holes as you want... but your going to have to pay for it in the end... I think making perfect measurements and wedging will be fine for supporting the 10-15 pound door.
If you want to have a thicker wall, you need to use a wider beam. I used 1.5", since dorm rooms are small I thought that this would be a pretty reasonable beam size.
Since you will be dealing with a smaller space, it is likely that you won't need that much wood. I covered the entire length of each wall with wood, wedging the opposing side into the 8' space. Cutting the edge of the beam at 45 degree angle will also facilitate the wedging process.
I used a sliding door that is wider than half the width of the wall, so you will need to have the door port off center ( that sounds much more confusing than it is). I also wanted to guarantee that sound and light would be blocked, so i made the door frame in inch shorter on each side and on the top. This would cover up future mistakes as well as assure that the door would cover the hole.
There are many different ways you can build the frame, just make sure there is an area that you can wedge the wood into. Also, remember where you put the beams this will make your job easier. Take a picture if you can not remember.
When you wedge and mount the outer frame, you can start mounting the inner frame. You can design it how you like, but use my blue print as a guideline. I also ran out of wood at one point, so on of my cross beams looks shortened. If you want to put a screw in at an angle, you will need to drill a pilot hole.
The blue print included uses angled cross beams, in order to accomplish this you will need to make two 45 degree cuts that are parallel to each other.
Add Comment
