Step 5Mount the Door
The mount that I bought is intended to be mounted so that the holes are parallel with the floor. I mounted the holes perpendicular to the floor, it worked out better for me. Follow the directions given with the kit, keep the plastic rail guides.
In order for the door to work well the rail needs to be pretty straight. Have a friend help you out. Add the wheels to the door, and slide it onto the tract.
The door may make a little noise, used WD40, it works like a champ and makes sliding work a lot better.
You can also add the door handle at this time.
Add Comment
