Introduction: Rope Ladder
Picture of Rope Ladder
So you need a way to get up and down from your tree house, but you left you ladder at home. Don't worry, just grab some rope and make this cool rope ladder.
Step 1: The Ropes
Picture of The Ropes
If you only have one rope, you can just fold it in half and start about 1 ft from the middle. I have used two ropes as it is easier to demonstrate with two different coloured ropes.
Step 2: The 'S'
Picture of The 'S'
Start the first rung by making a 'S' shape with the rope on the right (orange)
Step 3: The Wraping
Picture of The Wraping
Now pass the left rope (blue) over the top rope of the orange 'S'. Then under the middle and bottom ropes of the 'S'. You will wrap the blue rope around the three strands of the 'S'. Try to keep the wraps as neat and as tight as possible, this will make for a sturdier ladder. You will need between 8 and 12 full wraps for each rung, depending on the diameter of your rope.
When you have enough wraps tread the working end of the blue rope through the orange loop sticking out of the end of the rung.
Step 4: Finishing the Rung
Picture of Finishing the Rung
Tighten the loop by pulling the orange rope sticking out the left-hand side of the rung. This will hold the blue rope tight and complete the first rung. As you can see the blue and orange ropes have now changed sides.
Step 5: The Second Rung
Picture of The Second Rung
For making the second rung, follow the same steps as before but the ropes have changed places. Come down the blue rope about the same distance as the width of the first rung and then  make a 'S' shape with the rope. Pass the orange rope over, under and under the blue 'S'. Make your wrappings with the orange rope. Pass trough the blue loop and tighten by pulling the blue tail.
Step 6: Finishing Off
Picture of Finishing Off
Finish the ladder by repeating steps 1-5 until you run out of rope or you reach the desired length. Care should be given that each rung is level and tight. Depending on what rope you use there may be some stretching and it may feel springy when in use.
As with most things, it is best to practice this skill before you need rely on it or make one and store it in your Den or shed until needed.
Enjoy
kitteno made it! (author)2016-08-04
I made it but some of it took a lot of patience.
It is Amazing and feels much better on my hands and feet than wooden rungs.
Thank you so much!
VentureScout (author)kitteno2016-08-04
good job, it's worth spending the time to get it right and your ladder should last years
kitteno (author)VentureScout2016-08-04
Thank you!
SparkySolar (author)2015-02-21
I like the design
VentureScout (author)SparkySolar2015-02-23
Thanks, it looks a lot better when I used the two colors.
SparkySolar (author)VentureScout2015-02-23
Oops 1000 feets
I accidently got several 100 feet in black and blue for a belt , ( I tell you a secret( I have trouble with inches and feet. AsI grew up in Norway and Germany) LOL.
thank you for kind reply.
I am proud to be an American Citicen. Just not In inches
andersoninman (author)2015-01-04
how much rope do you need?
On the rope to ladder length ratio.
Again this depends on the type of rope you use, I used 9mm rope, the rung had 12 full wraps which made it approx 130mm wide.
The 'S' side used approx 450mm and the wrapping side used approx 1150mm.
This will change with the diameter and the type of rope used.
Also the spacing between the rungs will affect the length of rope needed.
I hope this answered your question, your best bet would be to try it out and experiment with different rung widths and spacing.
ENJOY
jakek99 (author)2014-08-28
Ok thanks
VentureScout (author)2014-08-25
Hi jake99, this one really depends on the type of rope and its diameter. I gave a breakdown in the comments bellow (see 'rope to ladder length ratio'). but at a guess I would think two 50ft lengths of rope should be long enough for a 20ft+ ladder. I would suggest experimentation as the number of rungs will also affect the outcome.
I'm sorry I cant give you exact figures.
Let me know how you got on.
jakek99 (author)2014-08-24
I mean length not diameter
How much rope does it take to make 20 feet
TheSurvivor99 (author)2014-04-23
What is the length of rope to total ladder length ratio?
I hope this answered your question.
That would depend on the diameter of the rope being used. I will take one of the rungs apart and measure it and I will post my findings.
pantherj12 (author)2014-04-25
How can you tell if it can hold your weight
VentureScout (author)pantherj122014-04-26
Your rope should have a rating or a breaking strength on the lable when you buy it or you could ask the shop assistant. Sometimes makers have breaking strength charts on their web sites.
If you are using old rope that's a bit different. Ropes lose strength over time, how much depends on how they were stored, used and possibly damaged over its life. So if you don't know your ropes history you should test it at low level before using it at potentially dangerous heights.
VentureScout (author)2014-04-25
Wolfbane221 (author)2014-04-23
Nice 250$ ladder ;) haha! Actually, this would be cool with my old ropes that developed a cut and are no longer safe to climb with!
VentureScout (author)Wolfbane2212014-04-24
haha I see what you mean! I did make it with blue polypropylene rope but the climbing rope made it look nicer and easier to explain. Yes I would save this one for your retired ropes, once they can still take a load!
hawcrofta (author)2014-04-23
Looks really cool.
About This Instructable
24,159views
800favorites
License:
Bio: Friendship is like a mirror, it gives you back what you are. You make a friend by being one.
More by VentureScout:3 Part Coffee Machine Emergancy Morse Code TransmitterThe Irish Lashing
Add instructable to:
