Rope Tackle for Pioneering Use (Trucker's Hitch)
14,546
184
7
Published
Introduction: Rope Tackle for Pioneering Use (Trucker's Hitch)
About: I believe in giving our Scout youth repeated opportunities to engineer and orchestrate the construction of useful pioneering projects. Building pioneering projects contribute to the development of self-estee...
When you want to lift or pull more than your own strength will permit, or when you want to make a heavy lifting job a little easier, the rope tackle is a device that can be used.
The idea behind a rope tackle is similar to that of a tackle using blocks and pulleys. In a rope tackle, one lead (end) of the rope has to be fixed. That is, it has to be anchored around a spar or tied through a ring or other piece of hardware that doesn’t move.
Follow this link for a full description with diagrams and illustrations: ROPE TACKLE FOR PIONEERING USE
Step 1: Form the Fixed Loop
Start with a Butterfly Knot in the desired position along the standing part of the rope.
Step 2: Use the Fixed Loop
When there is lots of line, make a bight in the running end and feed it through the fixed loop of the Butterfly Knot.
Step 3: Tighten the Rope
To tighten the line, grab a hold of the bight and pull it towards the anchor.
Step 4: Secure the Rope Tackle
When the desired tension is put on the line, with one hand, keep the line taut, and holding the bight in the other hand, use the bight to form a half hitch around both tight lines.
Step 5: Maintain the Tension
As the half hitch is secured, maintain the tension on the line by pinching the standing part, making sure it doesn’t slip.
Step 6: Dress the Half Hitch
Still maintaining the tension on the tightened lines in the standing part, cinch the half hitch up close to the fixed loop of the Butterfly Knot.
Step 7: Finish the Rope Tackle
As an added measure, tie another half hitch around the tightened lines. All excess rope should be coiled under the knots.
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    7 Discussions
    I had to look up what it is called, but I use a Magnus Hitch rather than Two-half Hitches. It holds the rope tighter so you don't have to slide the hitch right up against the Alpine Butterfly. Makes it easier to untie.
    Yes! I RECENTLY came across that alternative. In pioneering terminology, the common name for the Magnus Hitch is Rolling Hitch, and though I haven't yet used it on a rope tackle during a real life setting, by its very nature I know it works great! It's one of my favorite pioneering knots, and using it simplifies the rope tackle procedure—namely, less messing around to keep the line taut as the tackle is secured. By the way! To grasp how the Rolling Hitch is functioning, in this application it can be seen as Taut Line Hitch around the bight! What can be more simple?!
    However, with further application and thought, when not cinching the hitches flush against the fixed loop, the rope can slide. After all, a taut line hitch (rolling hitch around the standing part) is tied to maintain tension on a guy line, BUT it's also designed to slip.
    Thank's, I'm learning. I'v been meaning to learn more about knots.
    Did this last summer with scout troop, and we hauled logs around for making our lashed tower. Love these pioneer skills! Well done.
    Great stuff Larry. Fairly easy to grasp, it helps to have a rope handy :)
    When the line is shorter, just thread the running end through the fixed loop without making a bight.
