Each free end then goes under your armpits, before crossing behind you, over the rope bundle... This will prevent the rope from bouncing around as you're walking.
Finally, the free ends are tied together at your waist (over your stomach) using a reef knot.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
Do NOT underestimate the benefits of using doubles to avoid rope drag...
Sam, coiling with just yer hands (not yer neck) is much faster. As long as your hands are big enuf to hold the middle (the part which would be behind your neck), you can just whip your arms apart and bring them back together for each side loop. A lot faster and probably a slightly higher coolness factor.
And, little monkey, you only have to reflake the rope once. Once you are climbing and at intermediate belays, things restack nicely if you are swinging leads.
Check out these sites:
High-on-ropes - Rope Glossary
Just Just Ropes
ABC of Climbing - Climbing Ropes
If you butterfly your rope correctly (starting from one end) you should never need to flake your rope out when you reach your next climb, because you already did the flaking in the process of making your correct butterfly coil.
I wanna try twins or halves for ice. Sure must make rapping easier.
Or end of the second pitch of 'prune?' Funny, I just ran into a guy last weekend at a local crag. He and I were involved in a rescue several years back when someone fell off the top of that pitch, zippered almost all his gear and got banged up pretty bad. At least 25 other climbers were involved the the rescue, too.
We were just walking up Roy Gap rd. when Markwell came toolin' up in his pickup and said "Drop your gear, boys." We humped all the first aid stuff, body board, etc. to the base of Prune.
I know another guy who broke his leg at the same spot. I finally led that pitch a couple years ago and it's not too bad, but it's not for someone who's leading limit is 5.7....
We call it the 'euro death knot.' Gets it's name cause it's nothing but an overhand knot and it looks scary. It's actually an excellent knot--the fat 'knotty' part is only on one side, so it slides over edges, etc. when you pull the rope. Almost never gets hung up. Long since gave up using a figure 8 or a double fisherman's...
