3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rose in a heart of ice
This instructable describes how to make a heart of ice containing a frozen rose.
Some days before Valentine's Day I noticed that it has already been some time since I last gave my wife I self-made, personal present. So I decided to use the opportunity and combined two symbols of Valentine's Day into a useless but romantic present: a heart carved out of ice which reveals a rose when melting.
My wife loved it.
Step 1Tools and materials
Tools and materials
To make the heart of ice, we will proceed as follows: First, we suspend the rose in a bowl of water and freeze the water (steps 2-4). Then we remove the frozen water from the freezer and carve it into a heart (steps 5, 6). Finally, we prepare a wooden socket for the heart and mount the heart on this socket (steps 7-9).
For this, we will need the following tools and materials:
  • A rose. It should be big and in full blossom.
  • A working place that may get wet. There is a certain amount of melting involved.
  • A bowl in which we will freeze the water containing the rose. Since we want the rose to be completely contained in the ice, the bowl should be large enough such that we can suspend the rose such that there remains some space (at least 1cm) on all sides. The bowl I used (see the pictures) was borderline, a somewhat larger bowl would be better. (I do not give measurements, since the correct size of the bowl is relative to the size of your rose).
  • Some wire to suspend the rose in the bowl (step 2). My wire had a diameter of 0.5-1mm.
  • A freezer for freezing the water (step 3). You will probably find one in your refrigerator.
  • A sharp knife or paper cutter. Used for cutting away the stump of the rose protruding from the ice (step 4).
  • A flat screw driver. This one is never mentioned in any of the steps, but it is occasionally useful when the heart gets frozen to some other parts and you have to detach it.
  • Several rough rasps for carving the ice (step 6) and also for preparing the wooden socket (step 7). Probably any rasps will do, but see step 6 for some information which shapes turned out useful.
  • One or two sheets of paper and a pair of scissors. The paper will be used to mark the rough form of the heart on the ice (step 6).
  • A piece of wooden board for the socket. It should be at least the size of the bowl, and it should be unfinished wood. Of course, it should also be as beautiful and elegant looking as possible.
  • A jigsaw for cutting the wood to the correct size (step 7). Other types of wood saw (electrical and manual) will do as well. (But a chainsaw will probably be unsuitable.)
  • Some rough abrasive paper for polishing the edges of the wood (step 7).
  • Coffee for colouring the wood (step 8). This is only necessary, if you want the wood to get a little bit darker (since in my opinion, dark wood looks more accomplished). Instant coffee is best.
  • A brush for applying the coffee to the wood (step 8).
  • A nail for mounting the heart on the wood (step 9). The nail should be approximately 15mm longer than the wood is thick. But the exact length is not important.
  • A hammer, otherwise the nail will be of no avail.
  • A Valentine/wife/girl friend or the corresponding male form (for simplicity, I will assume that the recipient of the present is female throughout this instructable). See step 10.
The preparation of this present took about 3-5 hours of working time. However, since there is a lot of waiting involved (the water must freeze, and the coffee must dry), you should begin working at least two days before you want to hand over the present. Since the final result can be stored in the freezer for a long time (indefinitely?), better start too early than too late.
If you have all the tools, the costs for this project should be minimal. I only had to buy the rose, the remaining materials could be found at home.
55 comments
1-40 of 55next »
Apr 27, 2012. 1:37 AMsusanchen2011 says:
So many tools are needed.
Nov 25, 2011. 6:33 AMnickpinspire says:
Oh man, this is a great idea and a good opportunity to dust down my carpentry tools. By the way I found this on our website, Pinspire.de. Weäre a young startup from Berlin and don't want to step on anyone's toes. If you'd like a link to our website please contact me at nick@pinspire.de. Cheers!
Aug 4, 2011. 10:09 PMmikesnyd says:
You could make a quick silicone mold of a heart you have found or made already the size you need. Then instead of using a bowl just dangle your rose centered in your silicone mold. Fill with water and place in freezer. Can be done really quickly.
Apr 13, 2008. 12:12 AMGonazar says:
Do you think it might be possible for it to bloom after you've frozen it, cause that would be wicked. The ice cold heart melting, then a blooming rose comes out. I wouldn't mind it being black as much if it could do that...
Apr 27, 2008. 8:20 AM-Aj- says:
when water freezes it expands, so freezing a flower all the cells burst and it dies. which is why any vegies that youve accidentally put in the freezer look weird and a floppy when you take them out, this is also why frozen plants look darker when they thaw out. similar to if you had squashed them. this is because freezing it damages it in a similar way. so unless you have a cryo chamber for your rose, it wont be able to bloom when you thaw it. water freezes cloudy because the dissolved gases cannot stay dissolved when it freezes and they come out of solution, leaving millions of tiny air pockets in the ice. by boiling the water first all the gases are forced out so when you freeze it there is barely any in there.
Oct 7, 2010. 10:40 PMdjin says:
So let's say I do have a cryo chamber.. will it come out red?
Apr 27, 2008. 10:10 AMGonazar says:
what if you froze it in liquid nitrogen? i vaguely remember some experiments on organic objects that kept their color.
Sep 21, 2010. 7:25 PMdani-e says:
That's great! haha very creative.. i just need to find the time to do it xD
Jul 11, 2010. 3:47 PMFlyinseamnky says:
I think your wife is prettier than the gift. = )
Jul 11, 2010. 11:18 AMrlee8807 says:
Remember that "Instant Ice" stuff that actually is like a plastic. As far as I know, that doesn't melt, so if it came out clear, you could actually mount it.
Feb 5, 2010. 3:50 PMToxicity says:
I love the fact that the rose turns black, a good little gothic touch for my GF.
Jan 29, 2010. 12:43 PMenid.dafiend says:
That is so awesome! The rose turns black. I would love to recieve it, even if it wasn't in the shape of a heart.
Oct 9, 2009. 8:17 PMilovegm says:
I'm terribly adversed to hardwork.
Do you think using a soldering iron to melt the ice is a good idea?
Not exactly familiar with the inner workings of the iron, wouldn't want to electrocute myself...
Oct 16, 2009. 8:34 PMilovegm says:
Good point, guess I shouldn't cheapen the effort put into a gift for my partner anyways.
Thanks for the reply, much appreciated.
Feb 13, 2009. 6:12 PMmariana.rodrigues says:
This looks great!! I plan to do one using a silk rose. The ice seemed to have burned the rose somewhat. A silk rose will look the same, regardless being frozen.
Apr 9, 2008. 1:21 AMfilthyfury says:
you can make transparent ice by freezing warm or hot water instead of cold, i dont why it freezes clear but thats how you do it
Jun 1, 2008. 10:55 AMearlvanze says:
Right there with you. Boil it first. Loses the surprise, but it's much cooler to see how the rose is actually suspended in it.
Apr 13, 2008. 12:08 AMGonazar says:
boiling the water gets the gases dissolved in it, therefore it doesn't form bubbles when you freeze it.
Feb 23, 2007. 12:16 AMStikk says:
Did anyone think the rose looked kinda weird when it came out of the ice? I mean this is an awesome idea, but it looked a little morbid to me, the black rose, but i suppose it would be kind of cool if you like that sorta thing. I'd prefer it if the rose stayed red, maybe using a fake one would work better? Just a suggestion, great idea though! :)
Mar 27, 2008. 12:22 AMFull Frontal Graphic says:
FWIW: With a peach coloured rose, I got a very cool looking flame coloured rose, yellow-orange-red colours.
Mar 27, 2008. 9:36 AMFull Frontal Graphic says:
No photo, sorry. But try drying some different colours, they seem to come out similar colours when dried as when frozen. But it was really tie-die flame-looking, from an innocent peachy pastel colured rose.
Mar 5, 2008. 9:47 AMinquisitive says:
Now a ring or earrings in the middle of the heart would be a really unexpected surprise, maybe enclosed in a capsule like the bubble gum toys come in? or a note or poem in it? I don't mind it cloudy-it adds to the mystery.
Feb 13, 2008. 3:08 PMGorillazMiko says:
Actually a very great idea.
Love it.
The rose looks all black at the end, looks really cool.
Probably too hard for me, I just might buy those Skittle heart things, fill that up with water, then freeze (and the rose part), then it would come out cool.
Nice job!
Feb 13, 2008. 6:59 AMBrennn10 says:
Creative! I like it!
Jan 16, 2008. 7:41 PMkillerjackalope says:
I think I may have my own take on this to do in another, like an absolute pscho instructable A series of timesavers called that would be cool... Sorry random tangent, If would personally boil the Ice etc make it clear, wait boil the ice, the water even then carve it and polish on side to clarity then sand the other to make it opaque, making a either a mirror effect of simply making the rose more interesting... also I think the effect of freezing make the rose more interesting, red roses are a bit cliched, black on the other hand...
Oct 30, 2007. 7:27 PMsunkist3208 says:
To make the ice crystal clear, you could boil the water, let it cool, boil it again, let it cool again and THEN put it in the bowl to freeze. It's always worked for me.
Oct 15, 2007. 2:54 PMnim6 says:
what if you used that clear ice instructable along with this?... just a thought..
Oct 9, 2007. 7:26 AMDragonknight says:
This is a really unique idea, but have you considered using a silk rose instead of as live one? The silk one will still maiintain it's color, and the ice won't blacken it... Neat idea, though!
Jul 2, 2007. 11:53 AMalex26i says:
They do make heart shaped ballons you know, I think all that wire inside the ice is kinda yuck, you can also use a silk rose from the dollar store. Then fill it with water.. Tie a knot.. Freeze and done, Later you can drill a hole and stuff a LED into it.
Jul 7, 2007. 2:54 PMlukeair45 says:
Could you use dry ice? Dry ice does not melt into water it evaporates, this would mean the rose would not turn black.....ewww
Aug 17, 2007. 10:12 PMCrysthala says:
Actually, it would theoretically be possible. Industrially, dry ice isn't produced by freezing it solid- it's cooled until it's a liquid, then the pressure is reduced off of the liquid. This causes some CO2 to evaporate, absorbing heat and letting the rest freeze into a solid. If lukeair could build a heart-shaped rose container, fill it exclusively with CO2, cool it with liquid nitrogen or whatever, then reduce the pressure, the rose could conceivably be encased in dry ice. Also, lukeair could conceivably start a business.
Jun 7, 2007. 10:42 AMtydeus says:
I think the rose turned black for the same reason most people can't freeze strawberries. The water around and in the cells of the rose freezes and make large pokey ice crystals. those crystals puncture the cells and well...imagine something half your size and shaped like a nail going through you...You can limit the size of the crystals by freezing the water very fast. Do this by first putting the roses (or in Alton Brown's case in Strawberry Sky, strawberries) in your freezer so that they get really cold but do NOT let them freeze. When they're nice and chilled, get them into a cooler of chopped up dry ice. The dry ice will freeze them very fast, even faster when the ice directly contacts the rose (that's why it needs to be chopped up). after that your roses are frozen and you can put them in the freezer for...ever i guess. Warning: dry ice is cold...like...really friggin cold.
Jul 15, 2007. 7:52 PMxxxafterglow says:
Man, I love Alton B. Cool instructable!
Jul 8, 2007. 8:36 PMchatterbox14730 says:
Thats really sweet, but why would you give her a BLACK rose?
Mar 24, 2007. 12:33 AMbluefreak0898 says:
try using warmer water lranging from lukewarm to hot to prevent bubbles and a more transparent overall outlook.
Feb 20, 2007. 10:00 PMRobyntheslug says:
apparantly, the way to make ice more transparent is to keep it gently agitated during the freezing process. Maybe one of those cheap little dollar store back massagers taped to the container and left on?
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Dominique Unruh
