Rosemary Garbanzo Beans
 by canida
A quick hearty dinner when you just feel like opening cans.
Step 1: Saute onion
Chop one onion and add it to a hot, oiled pot with some pepper.
Stir until onion softens.
Step 3: Add tomatoes and seasonings
Add either a can of tomatoes or a double-handful of chopped fresh tomatoes to the pot, and stir.
Add any other seasonings you like: I recommend a bit of dry oregano and thyme, and possibly a dash of paprika or chili powder. You can add a boullion cube or some anchovy paste for a bit more salt and depth of flavor. Mix everything together and continue to heat.
Step 4: Let it stew
Cook over medium-high heat just long enough for all the ingredients to heat up and the tomatoes to break down and mingle. They'll drop a bit more water, so if you forgot to drain the cans earlier you'll really be sad. Make sure you're cooking the mix at a simmer to get it moving quickly, but take care it doesn't stick.
Note that the color changes as the beans and tomatoes both cook down a little bit. Call it done when everything is hot, the tomatoes have softened up, and the liquid has mostly disappeared. You want this to have a stew consistency.
Step 5: Serve
Now that your beans have cooked down properly, taste and adjust the seasonings. Add salt, pepper, garlic, or lemon juice if it seems a bit flat.
Serve with chopped parsley or basil on top for extra style points. This also goes well on top of pasta, in which case you can leave a bit more juice/sauce on the beans.
defenestr8or says: Apr 3, 2010. 3:48 PM
Just wanted to let you know I've made this many times - it's become a regular - THANKS!
I was impatient once because I had too much tomato juices to evaporate and added some bulgar to soak it up, and now I do it every time. Works with many different kinds of grains.
scotthaskett says: Aug 1, 2007. 10:55 PM
This is a GREAT recipe! Thanks for sharing :)
ichipoodle says: Jul 16, 2007. 5:45 PM
P.S: You should add it to the cooking contest! Wait, did that already pass? Well, if there's another cooking contest, add it =P
ichipoodle says: Jul 4, 2007. 2:35 PM
canida, thank you so much! i tried a little curry powder in mine, and some basil instead of rosemary, and my whole family practically tears me apart to get me to cook some, and once i do, it's all gone in 10 minutes!
cpotoso says: Jun 27, 2007. 7:52 PM
It looks really good! I made also a variation using garlic instead of onions and the result is very good. Another suggestion: put the garbanzos last. First let the tomatos caramelize a bit in strong heat and when this is done put the garbanzos (they do not need to cook if they are canned, only get warmed).
inertia18 says: May 17, 2007. 3:44 AM
Great recipe! simple but a hearty meal indeed. Post some more. I do love cooking. I will post mine so that we exchange recipes
Ephdisc says: Feb 27, 2007. 2:49 PM
This is really cool, but i can't figure out how to roll the duct tape around your finger... Maybe a video could help. Otherwise, this is awesome... and Tasty!
irritant#9 says: Jan 26, 2007. 5:14 PM
Ausgeseichnet!
peterbryenton says: Jan 9, 2007. 5:02 PM
Tasty pictures too.
Crash2108 says: Dec 6, 2006. 9:15 PM
Did you get new bowls?
canida (author) in reply to Crash2108Dec 6, 2006. 10:15 PM
Nope- this is from a chips-and-dip set. Eric was dissatisfied with his photoshoot results using our standard set of bowls, so we dug this out. It's likely to make further appearances.
fungus amungus in reply to canidaDec 7, 2006. 2:01 PM
I love how you guys are digging deeper into food photography. There's just something great about that.
grass root says: Dec 6, 2006. 10:13 PM
I do something very similar, just leave out the rosemary and add curry paste. I'll be sure to try your version though, it sounds great.
canida (author) in reply to grass rootDec 6, 2006. 10:19 PM
We make a garbanzo curry too- I haven't posted it here yet. I'd love to compare curry versions.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
