Introduction: Rower Mount for Computer Monitor
Picture of Rower Mount for Computer Monitor
I have a Concept2 model D rower.  I like to use the RowPro http://www.digitalrowing.com/ training software or watch videos while working out.
I did a search and found some designs but I found them to be a bit kludgy, overcomplicated, and/or requiring an expensive mount or arm.  I figured out a simple setup using a cheap VESA mount and one piece of angle iron.
This is pretty easy. The angle iron will bolt to the left side of the chain guide.   Replace the bolts PNs 1201, 1231, and 1266 for some slightly longer ones to accommodate the extra thickness of your angle iron.  Turn the bolts around so that the nuts are on the left.
Use part 2140 as a template to drill your holes.  Transfer punches are your friend.  Don't use bed frame iron, it's a bastard to drill.
I found a cheap VESA mount on Amazon which worked perfectly.  US http://www.amazon.com/gp/product/B000VKCIJU/ UK http://www.amazon.co.uk/BestDealUK-Universal-Profile-Monitor-Bracket/dp/B0099DDJWK/  This mount allows the monitor to be removed easily.  Mount the wall plate so that the PM doesn't block your view.
For 20 bucks in parts I think it's a nice clean solution.
nowammy (author)2016-11-26
This is an awesome mount. I almost made one for my concept rower and then I saw another mount option from rowfree.com . I went the lazy route and bought that mount, but if I wanted to mount a big monitor instead of just holding my iPad, yours would definietly be the way to go!
JoeK97 (author)2016-05-04
That looks great! How long did you cut the angle iron? Height looks perfect, would like to duplicate your design.
walkthewalk (author)JoeK972016-05-05
My angle iron is 33". Make sure that the PM doesn't block your view.
Raamah (author)2016-04-07
What size monitor did you use? Does it wobble a lot when you're rowing? Your monitor mount is the best idea I can find online, looks great :)
walkthewalk (author)Raamah2016-04-08
It's a 17". It doesn't wiggle much at all.
About This Instructable
2,945views
5favorites
License:
Bio: I'm a big believer in KISS (keep it simple stupid). Utilitarian design appeals to me.
More by walkthewalk:Rower Mount for Computer MonitorPallet BreakerMy Shop
Add instructable to:
