Rubber Band Powered 3D Printed Rocket
1,620
14
5
Posted
Introduction: Rubber Band Powered 3D Printed Rocket
Space Challenge
This is an entry in the
Space Challenge
In this Instructables, you'll learn how to build a rubber band powered 3d printed rocket.The Rocket is designed usingTinkercad
If you've never used Tinkercad before,read through Jonathan Odom's free EASY 3D PRINTING CLASS.
Let's begin!
Step 1: Tube Design
Open up a new 3d design in Tinkercad,
For building the tube, the shape we need to create is a simple cylinder.
  • Drag a Cylinder into the Tinkercad workplace
  • Adjust width and depth to 15 mm by clicking the white corner
  • Adjust the height of body tube to 80 mm
  • Make a copy of above cylinder and make it hollow, adjust width and depth to 13 mm
Step 2: Fins Design
  • Drag a Pyramid into Tinkercad Workplace
  • Adjust width into 34 mm
  • Adjust height into 31 mm
  • Adjust depth into 1 mm
  • Make a copy of above part and rotate it by 90 degree
Step 3: Nose Design
  • Drag a Cone into Tinkercad workplace
  • Adjust it's width and depth to 15 mm
  • Adjust height to 15 mm
  • Drag nose to a height of 80 mm
Step 4: Hook Design
  • Drag one more Pyramid to the workplace
  • Adjust depth to 1 mm
  • Adjust width and height to 5 mm and 15 mm respectively.
  • Drag it to height of 65 mm
Step 5: Watch Video!
The below video shows Tinkercad design of this project
Step 6: 3D Printing!
Export the design as .STL file to prepare for printing.
3D file is available at https://www.tinkercad.com/things/bHzAGyY7kv5#/
Step 7: Making Rocket From Scratch
Since I don't have access to a 3d printer,I could not upload the 3d printed part image.
But!
I am a Maker
So I have made a rocket from scratch.I used an old pen's tube and foam boards to build this.I used foam board to build both fins and hook.
  • Cover Pen tube with insulation tape
  • Glue fins and hook by using hot glue gun
  • Use rubber bands for launching
Step 8: Final Look
Step 9: Launching!
HAPPY MAKING!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    4 Comments
    hello rebeltaz,
    I checked your rubber band powered rocket design on thingiverse , The design is far better than mine ,
    I've liked your design on Thingiverse .
