Rubber Band Purse Clutch
373
Posted in HomeReuse
Introduction: Rubber Band Purse Clutch
About: Electronics Engineer | Developer | Tinkerer | Entrepreneur | Android | Web
Here is how you can make a purse/clutch using rubber band. It is strong and you can make it using recycled materials like rubber band, cardboard, etc. Easy to make, use and entirely based on rubber bands.
This instructable is up for the Rubber bands contest. So please vote if you like and find it useful.
Things you will need :
1. Cardboard
2. Rubber bands
3. Glue
5. Some card paper
Step 1: Template
Cut the card paper as shown or as per your choice.
Step 2:
Take the two cardboard pieces and clip them together
Step 3: Vertical Bonding
Glue the outer surface and start placing rubber bands on it.
Place the bands at a gap of 1cm from each other. Make sure they stick well.
Step 4: Horizontal Bonding
Use glue again and place the rubber bands horizontally.
The bands should bind the card boards together firmly.
Step 5: Making the Slit
Cut the bands from one side to make an opening to keep your things.
TIP- Use hot glue to bind the rubber bands. I used glue and some bands started falling out, though made a good design later :D Looked like the equalizers in music apps.
Step 6: Making the Cap
The purse clutch is tight enough but you can add a cap to just make sure your money, paper doesn't fall out as shown.
Take a piece of card paper, add some glue and stick it to one side of the purse clutch. Then fold the card paper as shown to form a perfect lock.
Step 7: Finalize
Use glitter or colors to make the purse clutch more attractive :)
Please Share and Vote if you like.
This Instructable up for the Rubber bands contest. So please vote if you like :)
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
