Rubber Band Shooter
996
Posted
Introduction: Rubber Band Shooter
As you can see there is a giant hole type crack thing you DO NOT need it the shooter can also make little sounds if you pluck the rubber bands.
This project is cool and easy to do. If nail is put in wrong, the best way to take it out is to use pliers or attach nail to drill and pull back.
Also you can attach a piece of wood to the opposite end of the part with the rubber band so the nail doesn't fly off but hasn't happened to me yet.
Step 1: Materials
You will need a circular piece of wood, a small rubber band and 2 nails. You CAN use a drill bit smaller than the nail to make it easier to get the nail in the wood. You do not want to crack the wood. Use a hammer to hit the nails in.
Step 2: Nail Tip
Use a small drill bit to drill into the end of the circular wood piece, then hammer the nail into the wood piece.
Step 3: Trigger
Use your drill bit that you used on the tip to drill through the wood upwards. You may sand down the edge of the trigger. Wiggle the nail around to make sure that you can pull the nail in and out easily.
Step 4: Rubber Band
Attach the small rubber band to both nails. To make a sound lift up the nail and lift up the rubber band.
Step 5: How to Fire
Pull down on the opposite side of the rubber band to fire!
Step 6: Information
If you have a question or suggestion leave a comment. If you cannot figure something out I will be happy to help.
                                                            HAVE FUN SHOOTING
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
    The nail is a suggestion you can sand the tip like I did. Thanks for the comment I'll add it to the instructions as something optional to do.
    yeah it looks like fun until the sharp building nail gets acidently shot out at a target and scares the blessings out of you i have experince with a similar thing if you use a pencil to hold on the wrong end it shoots sometimes if overloaded so you should have a emergency machanical mechanism such as a wider percentage of a nail head and file the tip so it does not damage the elastic causing it to snap becuase if something happened under good sumartitian consideteration and results it would be unfortune and i mean this in a constructive manner so just try to inprove good luck , this would give extra qualities for the be nice policy see i am sure i was an acident and i understand but just be wise and mature and deal with it, no offense of course but somethings are better to mention then not to mention so have a good blessing good luck
