loading
Step 11: After fixing the wings.
- It should look like the picture after you have glued the wing to the wire.
- Taped the remaining Wing cut-out as shown in the diagram.
<p>please email me the wing cut out to - constancezouroudis101@gmail.com</p>
Please download from this link : <br><br>http://www.kiddyhub.com/download.html<br><br>Thanks<br><br>
<p>please email me the wing cut out - constancezouroudis101@gmail.com</p>
Hi,<br><br>You can download here :<br>http://www.kiddyhub.com/download.html<br><br>Thanks<br>
<p>I made the butterfly, but it doesn't fly well, it goes down, sorts of a freefall. What can I be doing wrong?</p>
<p>Hi Sorry for the late reply.</p><p>The body may be too heavy and you need to put oil between bead and rotating wire.</p>
I would appreciate an email with the pattern also <br>Linwhittle@gmail.com <br>thanks!!
ok
Can you please email me the pattern!please
what is your email ?
Famouskid1000@gmail.com
I would love the pattern email to me. The surveys won't load on my computer...the world just turns, and turns and turns! <br> <br>louanncrum69@yahoo.com Thanks!!!
I would like the pattern as well. Thank you very much.
your email please ?
I would like to download the wing pattern too. The surveys never end, and I cannot get the wing pattern either.
please send me your email.
Can you email me the wing pattern please? The surveys are never ending!
im unable to download d pattern of the wings :(
what's is your email ? I sent to u :)
can yo pls tel me how to make the wings ?? <br>
Please download at : <br> <br>http://web.singnet.com.sg/~csqf2828/Butterfly_Art_Ideas.html <br> <br>
The surveys will no tload on my computer, it says direct link disabled. please help!!!!!
wat's your email ?
Thank's for the help. I have it figured out. I just took a quick trip to my local library and printed it out there.
can you post another link for the wings?
will a straw work for the tube?
straw is too soft...the tension from the rubber band will crush it :)
tape electical tape around the straw, to make it more sturdy
&nbsp;i use a straw, and it just works fine... but i can't download the wings :P
oh yeah attach a very very very small recorder on the bottem and spy away!
thanks
thanks for the support :)
I dont like the surveys........ its telling me to download stuff<br>my computer's slow as it is
send me your email address.. to info@kiddyhub.com <br> <br>
i think that if you become a pro memeber then we should be able to get the measurement s for the wings straight away . <br>the link dosnt work
there is a simple survey to answer before you can download..so at least I can keep my free site going :) . <br> <br> If you got a problem downloading ... please email me your address and i will send it to you.
i cannot get the pattern for the butterfly how do i get it and i need it today <br>thanks
PDF file not download
please try again.. after completing the survey, thanks for the support
CANT DOWNLOAD WINGS! HELP!!!!&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ,thanks
Is there another place to download the pattern?&nbsp; I&nbsp;refuse to take the surveys that are required.<br />
nice one.but mine won't fly if i turn it more than 20 rounds...
oh..the body must be light ...
aluminum wire okay?
i got an fantastic idea! try to make a the biggest rubber band butterfly and try to get in to guinnes world book of records, eh, good idea? i definitely gotta make one... btw does it just fly up or does it to fly it forward if yes how far does it fly then? UR AWESUM!
will it really fly??
Yes.. see video :)
What sort of metal wire did you use? It looks like a straightened paperclip, is my guess correct?
Hi, No..paper clip is too heavy and hard to bend. I use those single core electrical cable you can purchase from the electronic parts shop. Size is 1/0.6 ..something like the solder but not too soft. The ideas is to be as light as possible :) Rdgs
wat about metal from a rulers edge ?
About This Instructable
89,471views
97favorites
License:
More by Kiddyhub:DIY Microcontroller - Hand Dynamometer Rubber Band Flying Paper Butterfly
Add instructable to:
