3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rubber Band Gun - Pistol Style (Chopsticks and RubberBand)
I'm Pretty sure that you have seen other Rubber Band Guns using chopsticks but you probably never seen a personal size one. If you have let me know i have to check it out XD. But i have made a experimental pistol using only chopsticks and rubber band. No tape, no glue (don't really trust it), nothing else but those two and my multi tool (but not really used to materials but tools itself).
Materials Needed:
Two sets of good chopsticks (I don't recommend the cheap teriyaki/chinese type easy to break)
5 or 6 Rubber Bands (make sure they are good ones not warn out or it might snap)
A sharp knife (I use needle nose pliers to cut them perfectly)
A small flier for metal (Optional but high recommended for fine crafting)
P.S. Careful cutting it if your going to use needle nose pliers (lost almost half my hand to them)
Step 1Collecting the Materials
Make sure you have your materials ready.
Two sets of Chopsticks and 5-6 rubber bands.
P.S. I only have one set of chopsticks left and a few rubber bands XP.
4 comments
Aug 25, 2008. 1:49 PMjosefu0 says:
it was weak
Nov 5, 2009. 9:49 PMZoticus says:
just duct tape a chopstick on the bottom of the barrel.
Apr 25, 2009. 3:07 PMjball13 says:
mine worked fine
Nov 10, 2008. 12:22 AM15zhangfra says:
thes are semi auto to, you load a rubber band on, then loop a nother one over the other way to the sticking out part of the handle keep on doing that , the bands on the handle must be taught. fire, then move the trigger back till the wronway band is off the ttrigger mech. go to oggcraft on youtube to find out if you dont get it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lansmart
I'm Azn and Proud.
