loading
loading
Picture of Rubens Tube 8 foot long AMAZING
Fire + Fire + Sound = Amazing
This is a 8 foot long Rubens' tube its amazing you should build one.
Shopping list:
Long pipe larger the better in diamiter (got mine for scrap jard)
Gas fittings for tube and to your gas bottles
Drill
2m drill bits
Rubber glove
Step 1: Drilling the holes
Picture of Drilling the holes
Our pipe is two staleness steel pipes 3.5inces in diameter 8 feet long.
Measure out 2m hols every 1.5cm along your pipe, make sure to leave a few inces from both ends of the pipe.
Clean up holes with meetle file.
When drilling such small holes you should poor some wanter on drill bit it makes such a difference.
Step 2: Diaphragm
Picture of Diaphragm
Cut out large pease of rubber glove to cover end of open side of tube.
Leave one side of tube blocked. When stretching rubber over sends make sure to tape down. The speaker with to put against this side of rubens tube.
Step 3: Gass connections
We split pipe into 3 drilled 2 large holes between connections. We then welded in gas connections to bottom of pipe and connected using gas fitting and a T junction back to gas bottle.
Reason for having two inlets in pipe was to improve on spread with filling up pipe with gas.
Step 4: Holding box
Since we where looking to do this outside we built a box around the tube so we can play this ouside, without this the wind blows out most of the flames. We initally used glass front but replaced with 3mm plexy glass to make it lighter.
Step 5: Get it going
1. Connect the gas
2. Turn it on
3. Let the gass fill up and light gas.
You should see a contant level of light flames along the top. It its not level check level of pipe.
Connect up music and let it play.
Step 6: More
First video and tube we made from copper did not work the best but you can certainlly see effect.
Also attached images of building.
Pumba1515 days ago
This is cool! I made one and wanted to make a box so that it could be used outside. What did u make yours out of? And how did you regulate the temperature? Thanks
it looks awesome
lisass3 years ago
It is amazing. I Just have heard industry Ball Mill before from Henan Zhongke Engineering Technology Co.,Ltd
lisass3 years ago
Wow ,that's so cool .
etarasov3 years ago
Wow. Definitely going to try this .
namit (author)  etarasov3 years ago
Its a lot of work and a lot of drilling deftly going to use small wall on tube next time.
LAWNMUSIC3 years ago
Very cool. Definitely going to try this. Doesn't look like you entered so here's a link for Scoochmaroo's weekly challenge which happens to be fire. http://www.instructables.com/id/Scoochmaroo-Challenge-FIRE/
Entries must be PUBLISHED during the contest period...
scoochmaroo3 years ago
Wow. wow. wow.
nccwarp93 years ago
Music selection ??? :)
namit (author)  nccwarp93 years ago
Lots of them, transformers, dubstep and 8bit music.
namit (author) 4 years ago
Updated video of tube working
