I'd like to extend a special thank you to Oscar for all of his help and photography on this project.
Remove these ads by
Signing UpStep 1Gather Materials
- An aluminum tube around 2" in diameter (pvc will work, but you'll have to cover the top in foil tape, and check to make sure it doesn't overheat while on)
- 2 clamps for 2 1/4" chain link fence (these hold the fence to the upright poles)
- A log of some description
- Screws
- 2-3" PVC end cap
- Masking tape
- A ruler or measuring tape
- 2 part epoxy putty
- A sheet of latex, rubber, or plastic that can withstand some high temps (test it in the oven on its lowest setting, if you notice strange things or bad smells after ten minutes, you need another material)
- Zip ties
- "L" brackets
- A butane tank
- A butane tank regulator
- >3 ft of 3/8" polyurethane tubing
- 3/8" barb adapter
- A stick lighter
- A small speaker
- Duct tape
- A drill
- 1/16" Drill Bit
- A step drill
- A punch
replay please
:D
You do know that discouraging admonishment is the fastest way to get DIY people to do something, right?
